How to make some fields (system and custom) required if system field got value?
Serj Shcherbakov
Hi!
I have Components field.
and if Components value = Bug i need to make Description (system), Date (custom Date), Select list (Single) as required.
How i can do this?
Serj Shcherbakov
Hi @Alejo Villarrubia [Adaptavist], I solved it is.
My code, for newbies:
! issue.components*.name.contains ('Bug') || issue.description as boolean
! issue.components*.name.contains ('Bug') || cfValues['Office'] as boolean
! issue.components*.name.contains ('Bug') || cfValues['Date of the bug detection'] as boolean
Thank you so much for cowork!
Betsy Walker {Appfire}
August 25, 2015
Hi @Sergey Shcherbakov -
If you want to avoid code, you can use the Update on Transition for JIRA add-on from Bob Swift Atlassian Add-ons which comes with a validator named "Conditioned Validator."
With this, you would:
  1. Add a validator to the appropriate transition of your workflow, and choose "Conditioned validator"
  2. For Condition 1, type "%transition_components%:%transition_description%#%transition_MyDate%#%transition_MySingleSelect%#" into the first box (without the quotes), "Bug:.*##.*" into the second box (without the quotes), and select the Negative checkbox. This says to compare the concatenation of the Components field, description field, a custom datepicker field named MyDate and a custom Single Select List named MySingleSelect to a Regex expression that contains "Bug:" and nothing else (which it would be if any of those 3 fields were empty. The Condition1 must be true to "pass" the validation so we use the Negative checkbox to negate all this, in essence saying "as long as those concatenated fields don't match "Bug:" and nothing else, then all's good! wink
  3. The Message field provides the text the user sees if this validation is NOT passed.
  4. This screen print shows it all:
  5. Click Update, then you should see something like this (color coding used to separate the fields):
  6. Publish your draft workflow and you should be all set.
Please note:  The above assumes the Component, Description, MyDate, and MySingleSelect fields are all visible on the transition screen, which is why they are referenced with a prefix of "transition_".  If any are NOT on the transition screen, then replace the "transition_" prefix with "original_".
Hope this helps,
Betsy
August 24, 2015
Hi Sergey,
You can add a Simple Scripted Validator for each of those fields that checks whether the component has Bug as value or not.
You can find some examples of how to do that in the following snapshot of what will be the new documentation website, which will be released together with the next version of the add-on: https://scriptrunner.adaptavist.com/3.1.5-SNAPSHOT/jira/recipes/workflow/validators/simple-scripted-validators.html
atlassian, jira product discovery, product operations, product ops, linkedin live, atlassian events, cross-functional collaboration, product management, engineering collaboration, design collaboration, atlassian learning, agile teams, product strategy
Product Ops Unpacked: 4️⃣ tips every product pro needs to know ✍️
Join PM Evangelist, Axel Sooriah, & Product Ops. Consultant & Advisor, Jenny Wanger, as they unpack the role of product ops and discuss key takeaways in Atlassian’s ‘The Product Ops Mission’ guide. They’ll answer your questions live on May 6 at 9:00am PT.
Register here ⬇️
