How to override webpanel detail-module in jira issue detail page?
Dang Thi Thuy Tien
September 7, 2018
I'm having a trouble when trying to custom the Jira's issue detail page.
Usually, the issue detail page, we have a link to view the workflow's graphic.
Now I
Screen Shot 2018-09-07 at 5.04.12 PM.pngThat web-panel has the id="details-module". Now I want to replace that web-panel by my custom tom web-panel. So I added this to atlassian-plugin.xml.
<web-panel
key="details-module" system="true" location="atl.jira.view.issue.left.context" weight="100">
<context-provider class="jira.plugin.viewissue.DetailsBlockContextProvider"/>
<resource name="view" type="velocity" location="/templates/jira/plugin/viewissue/detailsblock.vm"/>
<label key="viewissue.subheading.issuedetails"/>
</web-panel>
 Some how when I run it, the default web panel still appear above of my custom web panel, like this:
I can write some Javascript code to hide the first web-panel but it's just a workaround and sometimes it doesn't work.
Is there any way to hide the Jira's default web-panel?
Any help would be apprecieated.
Aleksandr Zuevich
September 7, 2018
I suppose you can modify \atlassian-jira\WEB-INF\atlassian-bundled-plugins\jira-view-issue-plugin-7.9.2.jar\atlassian-plugin.xml and delete web-panel module with details-module key. But it's also some kind of workaround and it's required additional attention during Jira updates.
Dang Thi Thuy Tien
January 10, 2019
Thank you @Aleksandr Zuevich
