If we invite users of another project to our Jira project, do they go into the license cost?
Revin Mathew May 8, 2019
Since the Jira license fees are on a per user basis, If we invite existing users of another Jira project into our project, do those users go into the license cost of both the projects?
Example:
Project 1 has User 15 users
Cost per user is $7/month
Total = 15*7=105/month
Project 2 has 12 users including user X
If I invite user X into Project 1, do you bill project 1 at (16*7)=$112 now even though User X is already being billed to Project 2?
Jack Brickey
Costs are per instance not project. Once you are a user in the instance you can have access to any project you want. Controlled by permissions of course.
Sorry, I should have clarified, by project above, I did mean instances. So a user who is part of two instances, do I go into the billing count for each of the instances?
Jack Brickey
Yes sir. You pay for users per instance so you might consider combining.
Like Revin Mathew likes this
Thank you.
