I have my boards set up but I have no where to put in my story point estimates. I have the board set to story points but no field to enter this information. Can someone please help me?
If you click inside an issue, is there a field for Story points?
Or, can you edit an individual issue and see that field?
Also, I think this is better suited as a "Question" rather than a "Discussion." And you might get answers a bit quicker too.
To be honest I have been looking all thru the JIRA documentation and clicked on a link that brought me here to ask a question. My intent was not to start a discussion. I was able to figure it all out on my own since the documentation was not helpful in the least bit.
The doc can help, but sometimes it's not easy to ask the right question.
Could you share two screenshots with me? One where you've set the board to story points and you describe, and another where you're expecting to see a story points field but aren't.
Also, are you an admin? Because the next step is to check some configuration settings to make sure you're setup correctly.
