I've specified the CSV file, selected a project to import into. I'm stuck at the screen titled Map fields. The Next button just will not get enabled.
Any ideas?
Stuck in Jira hell!
Does you CSV file follow all requirement to a csv file mentioned here:
https://confluence.atlassian.com/adminjiracloud/importing-data-from-csv-776636762.html
Could you share a screenshot?
Hi Alexey,
Yes, the CSV file conforms to the requirements mentioned at the page you provided.
Here are the screenshots. As you can see the Next button is just not enabled.
Thanks!
You did not map a field from the csv file to the summary Jira field. You must have this mapping.
You are welcome! If my answer helped you, kindly mark my answer as accepted.
