Hi.
I'm triyng to customize some issue status color in Jira.
Is it possible using "Raw XML Module"?
Hello @Alex Sander
I have not been able to find (through internet searches) a method that specifically uses that ScriptRunner module.
If you are open to using a different third party app I found several in the Atlassian Marketplace when I searched for "status colors":
https://marketplace.atlassian.com/search?hosting=dataCenter&product=jira&query=status%20colors
Hi @Trudy Claspill, thank's.
I'm going to check these apps.
I was figuring out a sollution with ScriptRunner 'cause is something very specific that I need.
Well, I did it work, not by a XML raw, but adding a javascript to a Custom Web Panel.
I've created a groovy script like this:
def script2 = """
<script>
(function() {
function applyCustomStyles(searchElementSelector) {
// Define the mapping of text to colors
var colorMapping = {
'GDM Reprovada': { backgroundColor: '#CD5C5C', color: 'white' },
'GDM Aprovada': { backgroundColor: '#006400', color: 'white' },
'Cancelado': { backgroundColor: '#F7DC6F', color: 'white' },
'Devolvido': { backgroundColor: '#7B241C', color: 'white' },
'Concluído com Alerta': { backgroundColor: '#DC7633', color: 'white' },
'Em execução': { backgroundColor: '#1D8348', color: 'white' },
'Plano em execução': { backgroundColor: '#1D8348', color: 'white' },
'Aguardando Execução': { backgroundColor: '#3498DB', color: 'white' }
// Locate the elements with the desired status text
var elements = document.querySelectorAll(searchElementSelector);
elements.forEach(function(element) {
var text = element.textContent.trim();
if (colorMapping[text]) {
element.style.backgroundColor = colorMapping[text].backgroundColor;
element.style.color = colorMapping[text].color;
console.log('Element styled:', element);
// Call the function for different selectors
applyCustomStyles('.jira-issue-status-lozenge');
applyCustomStyles('.aui-dropdown2-trigger');
// MutationObserver to reapply styles for dynamic content
var observer = new MutationObserver(function(mutations) {
mutations.forEach(function(mutation) {
observer.observe(document.body, { childList: true, subtree: true });
console.log('Custom status color script injected.');
</script>
// this script is attached to a panel in UI fragments (only way that it was possible to work)
// so this is to hide de panel (the id must match with Panel in UI Fragmente created)
<style>
#custom-status-color-pgdm-issues {
display: none;
</style>
writer.write(script2)
But, it just works linking the code to a Custom Web Panel.
Works fine, but just in the issue view screens.
I tried to set the panel location to the header or banner page, but doesn't work.
I'd like that the status colors could be applied to other pages like panels.
Almost there.
Earning the Mindful Member badge proves you know how to lead with kindness, plus it enters you into a giveaway for exclusive Atlassian swag. Take the quiz, grab the badge, and comment on our announcement article to spread the good vibes!
Start here
