Is it possible to depict a project as a project structure plan?
Progressive
February 17, 2022
are there options to view your project and its content as a project structure plan like this:
project-structure-plan-with-project-areas-and-work-packages
Ideally, this is is somehow possible to convert your board/list/time just into this perspective by providing a certain hierarchy to all the certain tasks.
Is this possible? In general and specifically?
Thanks a lot!
Best, Ben
Dave Rosenlund _Trundl_
Hi, @Progressive (Ben). Welcome to the community.
AFAIK - not exactly like that, no.  And definitely not out-of-box unless perhaps you are using Jira Cloud Premium or Enterprise, or Jira Data Center.  If so, check out the Advanced Roadmaps capabilities inside.  Again, not exactly as you depict it — but maybe it will suit.
There is also Jira Align. It's from Atlassian but it's actually another, related, product unto itself (in addition to Jira).
Your other option is to look for something on the Atlassian Marketplace - you might find an add-on app for Jira that might get you closer to what you describe.
In my experience Structure and BigPicture are the most popular. Full disclosure: I work for the company that makes Structure.
But you can also craft your own marketplace search — for example:
https://marketplace.atlassian.com/addons/app/jira/top-rated?hosting=cloud&query=hierarchy
 Best of luck to you — I hope this helps,
-dave
P.S. You are more likely to get the right/best answers if you specify which flavor of Jira (e.g. Jira Software, Jira Service Management) you are using and which platform (Cloud, Server, or Data Center) you are on when you post :)
