Is it possible to link between one Jira project and more than one Fisheye repositories
Fahad V A
Is it possible to link between one Jira project and more than one Fisheye repositories, what I need is I have a Jira project PROJECT and suppose three repositories REPO1, REPO2, REPO3 and I need to link all the REPO1, REPO2, and REPO3 with the Jira project PROJECT.
What we need is, if a commit is made in the repository, the commits should be visible in the source tab of the JIRA project summary page, If I add a single repository in the repository path of the project, then this feature is available. How can I add more than one repository in the Jira project so that the commits will be visible in the source tab of Jira project summary page.
Pedro Cora
July 30, 2014
I believe that you can use the Smart Commits: https://confluence.atlassian.com/display/FISHEYE/Using+smart+commitsfor that.
