I want to transition an issue to a particular status. This execution is condition based. When an issue of a particular issue type is created, it is in "Open State". I want that if an issue of this particular issue type is created and condition is satisfied, the issue must be transitioned from "Open" to "In Analysis" state. I tried to do it via Script Post function and Script Listener using below code, but it did not work.
def actionId = 281
TransitionOptions skipConditions = new Builder().skipPermissions().skipValidators().skipConditions().build();
transitionValidationResult = issueService.validateTransition(technicalUser, issue.id, actionId,new IssueInputParametersImpl(),skipConditions)
if (transitionValidationResult.isValid()) {
transitionResult = issueService.transition(technicalUser, transitionValidationResult)
Any help would be appreciated.
No, you can't execute another transition while there is one in progress. Not with that approach anyway, your code needs to be a lot more clever than that, otherwise you end up in a situation where an issue has two status and no way of knowing which one it should be landing in.
Scriptrunner has a function that handles it right though. Have a look at "fast track transitions" under https://scriptrunner.adaptavist.com/latest/jira/builtin-scripts.html
Hello Nic Brough,
Thank you for the response.
I am aware that the "Fast-track transition feature" can be used but I cannot use it for this requirement because, the transition has to be performed by a different user and not the current user and we do not have a provision to set user here.
Hence, could you kindly let me know how to achieve this.
You could try it as a listener - catch the create event, interrogate the data in the event and trigger a second transition.
Earning the Mindful Member badge proves you know how to lead with kindness, plus it enters you into a giveaway for exclusive Atlassian swag. Take the quiz, grab the badge, and comment on our announcement article to spread the good vibes!
Start here
