Zephyer is for all JIRA instance and it applicable for all existing projects in jira. there is no way to assign for specific project
Hemant
Thanks Hemant !!
Hi Pooja,
Zephyr for JIRA is applicable to all projects in the instance. The visibility of Tests menu is global and can be denied based on the user permissions.
If you want tests for only one project, you can do it by associating the Test issue type to only that project. Refer this link https://confluence.atlassian.com/adminjiraserver071/associating-issue-types-with-projects-802592389.html for managing issue type schemes.
However the Tests menu is visible you will not be allowed to create Tests for other projects where the issue type is not available.
Zephyr Support
Thank you @Swapna Kumar Vemula [Zephyr]
That's too bad.
We have tens of users and tens of projects on our Jira account and we need your testing tool for just one of these projects (for now at least).
Adding the extension to our entire pool of users will be paying thousands of dollars a month instead of just 80 (we have 8 user in this project).
Unfortunately we will have to pass.
