Happy Friday!
I am searching for a way to eliminate the manual step of transitioning a Zephyr Test Case to "Done" when the Test Execution Status is set to Pass?
If seems there are very few links in the Automation tools in Jira that pull in Test fields such as Execution Status.
Thank you for your help!
Hi @Misty Meyers Happy Friday!
There are a few open suggestions to add more support to automation for tools like Zephyr, such as this one: https://codebarrel.atlassian.net/browse/AUT-1295
Until stuff like that is added, two suggestions I have are:
Best regards,
hello guys i have a question is it possible to execute tests in jira where i use xray in an automatic way if yes could you provide me how?
Hi @Ihab Palamino -- Welcome to the Atlassian Community!
Please check if Xray has a REST API function which allows executing the tests. If so, that could be called from an automation rule using the Send Web Request action.
