  • Community
  • Q&A
  • Jira
  • Questions
  • Is there a way to copy components from one Jira project to another and/or import from a text list that does not involve a paid plugin?
Rob Horan
July 20, 2016
I'm copying components from one project to another - manually - and this is painful.  I would love to find a way to just bulk copy the components over, or at least import from a list.  Paid components are not an option.
Nicolas Bourdages
July 20, 2016
You could use the CSV import tool to create a bunch of bogus issues with the components you want. It's messy as it leaves behind unwanted issues, but I think it would work.
Any reason why you can't use the the REST api?
https://docs.atlassian.com/jira/REST/latest/#api/2/component-createComponent
Rob Horan
July 20, 2016
Ummm... because I don't know how smile
Like # people like this
Nicolas Bourdages
July 20, 2016
That's a good reason. It might be worth the time investment if you're going to do that sort of task again. Personally, I use the CLI plugin whenever I can, but it's paid, so sad
For the REST api, you'd need some basic coding skills. Here's something to get you started:
https://developer.atlassian.com/jiradev/jira-apis/jira-rest-apis
Good luck!
Like Naomi likes this
Rob Horan
July 29, 2016
Martin Gregory
But that only works for Server :(
gianfranco franceschi
Martin, what do you mean?
That if I have got Jira Cloud there is no point in downloading the plugin?
Just by typing the question I realize that it may very well be the meaning :-)
Anyway, is there really no other options to accomplish this?
Best,
Gianfranco
Michelle Rau HP
January 15, 2019
I found a way to create a simple list of components (or labels) which I posted here: https://community.atlassian.com/t5/Jira-questions/How-do-I-get-a-list-of-active-components-in-JIRA-and-export-them/qaq-p/419207
I don't know about importing components from a list though.
Bryan Karsh November 7, 2018
I realize this solution uses a paid plugin. But I am adding it because I ran into the same need, and whipped something up. Hopefully it will be of help to folks.
This can be run via script runner in the script runner console. It's pretty crude -- it simply adds the strings in the list to the target project as components (if I have time, I will refactor it to be a little more flexible -- it's not that hard (for example) to copy the stuff from the source project to a target project).
import org.apache.log4j.Logger
import org.apache.log4j.Level
def log = Logger.getLogger("Component Backfill Script")
log.setLevel(Level.DEBUG)
def projectComponentManager = ComponentAccessor.getProjectComponentManager()
// The projectkey and id of where you want the components to be added
def projectKey = "FOOBAR"
Long projectId = 12345
def newComponent = ""
def componentList = ["apple", "banana", "orange"]
componentList.each {
newComponent = it
/* see the blank quotes below? You can specify description and user for each
component. But if you do that, you'll need to add logic that parses that
additional information, or programmatically pull it from components from
the source project
try {
projectComponentManager.create(newComponent, "", "", 1, projectId)
log.debug "Created component ${newComponent} for project ${projectKey}"
catch(e) {
log.debug "Ran into a problem creating a component for ${projectKey} n\" + e.message"
Rob Horan
November 7, 2018
Thanks - we didn't have scriptrunner, though.
Bryan Karsh November 8, 2018
No worries. If I have time, I will show a pure rest-api approach. :)
Daniel
Thanks Bryan,
i addapted your scrip to pull all components from one project and insert them into another:
//def projectManager = ComponentAccessor.getProjectManager()
Long projectId = 12345 // Project ID to copy components from
def projectKeyTo = "HSR" // Project Key to copy to
Long projectIdTo = 11111 // Project ID to copy to
def componentList = projectComponentManager.findAllForProject(projectId)
newComponent = it
the source project
try {
projectComponentManager.create(newComponent.name, newComponent.description, newComponent.lead, newComponent.assigneeType, projectIdTo)
log.debug "Created component ${newComponent} for project ${projectKeyTo}"
catch(e) {
Like ITMSD likes this
Daniel
def projectKeyTo = "ABC"
newComponent = it
the source project
try {
catch(e) {
Maxim Rodionov
September 24, 2019
It works for me! Thanks!
