Is there a way to create specific priorities for a project and or issue type in Jira Cloud?
Vinay Sharma
We need to create the following priorities for a bug issue type in Jira:
Critical
High
Medium
Low
Is it possible to configure it for a project where the project team can see these priorities only for bug issue type?
2 accepted
Nic Brough -Adaptavist-
October 5, 2020
Not system priorities - they are global on Cloud.  You would have to create a custom field if you want different priorities by project
Vinay Sharma
Thanks Nic
Liam Green
October 5, 2020
Hi @Vinay Sharma
You could do this using a custom field - you can edit the Priority field, but it would then change for all projects, using a custom field would allow more precision.
Hope that helps
Regards, Liam
FREE
