Is there any way to collect issues using Issue Collector inside email (outlook)?
Deleted user June 8, 2018
I need users to give feedback using email instead of web application
Prakhar Srivastav {Appfire}
June 11, 2018
@[deleted]
Issue collector is for Web Applications.
For email , you should use mail handler to create issue. You can use the default available mail handler or you can create custom as well.
https://confluence.atlassian.com/adminjiraserver071/creating-issues-and-comments-from-email-802592933.html
Regards
Prakhar
