Is it possible to apply Issue Level Security Scheme with Jira Work Management?
I tried it on my end but it seems that there is no settings on a Work management project setting on which I can apply the security scheme onto.
And also there is no field name security level to apply on issue type.
Can someone tell me if this is even possible?
What type of project are you using, company-managed or team-managed? You will see which type it is in the bottom of the left-hand corner when you are in the project. Please note that issue security is only available in company-managed projects.
