Issue Navigator problem - latest issue doesn't show up
Rumceisz
Dear All,
we experienced a problem that when we search for a project's issue (project=x) the latest (newest) issue of the project doesn't show up in the searchresults of the Issue Navigator.
The issue was created 2 hours before the search was taken.
We experienced this both for simple and advance search.
Anticipating your first questions: we checked all the permissions: everyíthing is OK with that.
What can be wrong?
Thanks in advance,
Rumi
Renjith Pillai
January 1, 2013
  • Do you have any custom post functions in the issue creation step that is making trouble with indexes?
  • You can confirm this in your workflow.
  • Do a reindex and let us know if this makes the issue visible.
  • Does the logs have any errors being reported for reindexing or plugin related?
Rumceisz
additional info for the bug: if we made any update on the issue, it will show up in the search results. So summarising: the newly created issues don't show up in the search results. After any update (e.g. commenting, status transition, etc.) has taken, the issue shows up in the results.
+1 weird thing: this in particular projects: I just tested in a different project that I created a few issues and these immediately shoved up in the search results.
Zul NS [Atlassian]
January 1, 2013
Please perform indexing and see if it works.
Rumceisz
hence our Jira is used more than 2000 users at the tinme, I opt not to do a reindex.
