Since the upgrade to latest LTS version 10.3.2 i cannot see the item of the issue types in the project settings the font color seems to be set to white. when i change to the dark theme is showed properly. only in white theme it is not visible.
Is there any fix or workaround?
Regards
Mohamed
It seems that there has been some mixed up with colors in Look and Feel.
It is fixed now ... just need to change the "Drop Down Menu - text color" from white to any darker color.
I am facing same issue after the upgrade to 10.3.2 . Even in search issues , advanced, the list of fields and functions appears in white color ...
How can we fix these issues?
after updating to Jira LTS 10.3.3 we face the same issue, Issue Types in the Project Settings menu appear in White font color...
and search issues , advanced, the list of fields and functions appears in white color too !
