Jira 8.20.1 Data Center
ProForm: Forms and Checklists for Jira Data Center 8.6.0
On the Atlassian website it is documented that ProForm: Forms and Checklists 8.6.0 is compatible 8.0.0 to 90.0 Jira DC.
However then I saw an issue that stated if your jira contained JCMA v 1.4.4 ProForm: forms and checklists cannot be enabled with that version of JCMA. Our Jira admin stated that the JCMA 1.44 plugin is included in the base jira plugins so the only way to upgrade that plugin is to install a new version of Jira. Is this correct? We would really like to use the ProForm: Forms and Checklists for Jira DataCenter but our version of Jira does contain the JCMA 1.44 version, we are planning on upgrading to Jira 8.22.6 but according to the documentation any jira version in 8.20.x contains the JCMA 1.44 plugin. Is there a way to upgrade just that plugin or is there a workaround? If not then ProForm: Forms and Checklist is not really compatible with jira versions 8.20.x.....
Your Jira System Administrator should be able to upgrade the JCMA pug in, just like upgrading any other plug in.
