Issues uploading another project into JIRA after doing a system restore from hosted Ondemand to local
Lanre Kalejaiye February 27, 2013
I performed a system restore of a project that was OnDemand into a locally hosted JIRA version that I purchased and it worked okay.
Now I need to upload another project into my local JIRA and the only options I show under my admin screen is External System Import. I'm missing Back up system* REstore system * Project Import
The teams production will be severely impacted if I cannot upload the other projects into this new local instance of JIRA.
richie_gee
February 27, 2013
Hi there,
Can you try the following documentation to see if this helps?
https://confluence.atlassian.com/display/JIRA/Restoring+a+Project+from+Backup
I believe you can write in to the support to get more assistance on your case.
Hope this helps :)
