Can someone know what's the problem? With JIRA 6.1 Project Pivot Gadget title and description are not resolved for Timesheet plugin, i.e.:
See also Issue #419 and JRA-35036.
Thank you.
This was solved by minor correction in pivot-gadget.xml, sorry for bothering.
We have a similar issue with versions:
Plugin Version: 2.0
 JIRA Versions: 4.0 - 4.2
Is there a resolution for a system where the plugin has already been installed and for a new install? We're evaluating it on a test server and would first like to fix it there.
Hi Richard,
Could you please try applying fix manually? See https://bitbucket.org/azhdanov/jiratimesheet/commits/53c05e2
You need to extract project-pivot-gadget.xml, apply changes, update plugin jar and reinstall (preferrable uninstalling first, restarting jira and installing again)
You can extract and update jar with the following commands:
$ jar xf jira-timesheet-plugin-2.0.jar src/main/resources/project-pivot-gadget.xml $ jar uf jira-timesheet-plugin-2.0.jar src/main/resources/project-pivot-gadget.xml
Hope it will help.
Thank you.
I expected this, sorry, forgot to add origin Issue #419
Your png is not displayed here, https://bitbucket.org/azhdanov/jiratimesheet/issue-attachment/419/azhdanov/jiratimesheet/1380096342.82/419/MSG_gadget.png works for me :-)
