Hi, i have JIRA running MS SQL Server with collation 'SQL_Latin1_General_CP1_CI_AS' with versions 5.2.9, 6.1, 6.2, 6.3, 6.4 it worked fine
i just upgrade to 7.2.0 version and now i found the message:
the database collation 'SQL_Latin1_General_CP1_CI_AS' and table collation ''SQL_Latin1_General_CP1_CI_AS' are not supported by JIRA.
also, if i search documentation abount installation of JIRA with sqlserver2012 i found that the recomendation is CASE INSENSITIVE
https://confluence.atlassian.com/adminjiraserver071/connecting-jira-applications-to-sql-server-2012-802592195.html
so what do i have to do in this case?
Change your database collation to Latin1_General_CI_AI and the health check will no longer show error.
(Always make changes on test database in a test jira environment before doing in prod)
The change was made in test environment,
What happens if i dont change the collation?
and if i install confluence this collation: Latin1_General_CI_AI
is going to work for both?
i changed the collation, and i receive the error
"Argument data type ntext is invalid for argument 1 of lower function". in log file, with table: "AO_54307E_VIEWPORTFORM"
when i try add sla based of requesttype specifycally in JQL filter
what should i have to do?
Did anyone ever receive a resolution to this issue? We are encountering the same issue. I've created a fresh database, set the collation accordingly, imported all the data from the prior database into the new database with the correct collation, and now jira wants an installation key. After providing the key, the installed version thinks there is no data. Is there a suggestion for resolving this issue?
Frank
