JIRA and ZenDesk Integration jira_escalated Label Not Applied
Alex Romano
Scenario
We integrated ZenDesk with two JIRA projects, so that creating a zendesk ticket could also create a JIRA bug. It applied the label jira_escalated, everything worked perfectly, and we were happy.
We took a long break from that process project, and are attempting to finalize it now.
The Issue
Several months (and many JIRA changes later) later, for a reason I have not yet identified, the label jira_escalated is no longer applied to the cards created via the integration.
What We've Tried
  • Verified the adds-ons project role had permissions
  • Tried different project, different issue types JIC
  • Turning off automation rules
  • Verifying reporter and label appear on create and edit screens
We're not finding much about this issue so I'm sure it's something simple I'm not catching. Can anyone assist?
Dave Liao
@Alex Romano - hi Alex! To confirm, you're using Zendesk's "Zendesk Support for Jira" Jira app?
Alex Romano
@Dave Liao
Yes
Version:1.0.21-AC
Like Dave Liao likes this
Alex Romano
for my own edification I will share that if your zendesk/jira integration is not working, check your automation rules, especially those which affect labels at creation.
eugenia
October 7, 2025
Hi @Alex Romano , were you able to find an answer or solution for this? I'm also running into the same issue with a new project. I've also checked project add-on permissions, screens (view, edit, create), no automation rules that would impact this, and am stumped.
