JQL Help: Return All Issues AND sub Issues WHERE Parent Issue matches set of JQL
Nikki Leonard
I am trying to create a filter for use in Roadmaps where I want to show only a subset of project issues.
  • I created a custom checkbox field, milestone type, and I want the filter to return all of the issues with 'milestone type = contract' AND the child issues of issues WHERE 'milestone = contract'
  • Here is my current query (generated from basic search) that returns only issues where 'milestone=contract' and not those issues subtasks: project = XXX AND "Milestone Type[Checkboxes]" = Contract order by created DESC
    How can I return the 'child of' issues? I have seen some similar posts but haven't found an answer that works. I am hesitant to get something like script runner app but will if that is the ONLY solution (surely Jira has a way as this is a simple request).
2 accepted
mauricio.groth
December 2, 2022
Hi @Nikki Leonard
As you're on Jira Cloud, the correct answer is to get an app that provides JQL extensions you're looking for.
With standard JQL, you can only get a list of issues and export them to Excel for further processing. This works if you want to do a one-off analysis. If your use case is more dynamic than that, look beyond standard Jira.
Standard JQL doesn't easily allow it, but you can quickly find the results using our professional indexing service JQL Search Extensions
  • You can use this query to find subtasks whose parents have Milestone Type[Checkboxes]' = Contract
issue in subtasksOfParentsInQuery("'Milestone Type[Checkboxes]' = Contract")
  • If you want to return both parents and subtasks please use the query below:
issue in subtasksOfParentsInQuery("'Milestone Type[Checkboxes]' = Contract") or project = XXX AND "Milestone Type[Checkboxes]" = Contract
Check out the documentation for more examples.
If you have any other questions, please contact our support. We’ll be happy to help you!
Best regards,
Maurício
Trudy Claspill
Hello @Nikki Leonard
Jira does not natively provide a way for you to get issues and their children in one query when the list of parents is dynamic. This page provides info on the native search functions available specific to Advanced Roadmaps relationships.
https://support.atlassian.com/jira-software-cloud/docs/search-for-advanced-roadmaps-custom-fields-in-jql/
You will have to use a third party app to get what you want. ScriptRunner is one such app, but there are also others, such as Jira Search Extensions.
