I created a web automation in Jira where I want it to send me a json with the fixVersions list. It should only contain the id and the released flag. I came up with the following solution. Is there a better solution where I don't have to loop and deal with json formatting?
"issue_id": "{{issue.id}}",
"issue_key": "{{issue.key}}",
"fixVersions": [
{{#issue.fixVersions}}
"id": {{id}},
"released": {{released}}
}{{^last}},{{/}}
or by filtering only the not-released ones
"fixVersions": [
{{#if(not(released))}}
"id": {{id}}
}{{^last}},{{/}}
Yusuf
Hi @Yusuf Kör ,
this looks about right to me.
I would hide away some of the complexity in a variable. Let's say you create {{releasedVersionIds}} - which you set equal to:
[ {{#issue.fixVersions}} {{#IF(not(released))}}{{id}}{{^last}}, {{/}}{{/}}{{/}} ]This way you can easily set up your request data like this:
"fixVersions": {{releasedVersionIds}}
More concise and easier to read/understand.
Alternatively and depending on the runtime receiving the data you could just send the info in separate arrays like {{issue.fixVersions.id.asJsonArray}} and {{issue.fixVersions.released.asJsonArray}} and zip them in you receiving runtime. That would look like;
"fixVersionIds": {{issue.fixVersions.id.asJsonArray}},
"fixVersionReleaseState": {{issue.fixVersions.released.asJsonArray}}
Hope this helped. What's your thought on this?
Greetings
Gideon
