I have created a new jira automation for round robin assigning tasks but it seems to never trigger. Also when I try to turn off or on any automation, or make changes to existing rules I get an unspecific error. I've attached the rule and how it's configured, and as you can see from the audit log, it's never triggering. I've also added a photo of the error i'm getting when trying to turn off a rule or edit a rule.
I'm using: Jira service desk 4.2.4
Jira Software: 8.2.4
Jira Core: 8.2.4
Was this resolved, if so any advice? I'm currently experiencing the same issue.
How was this resolved? I'm having the same issue but when the rule creates a issue. The moment I add a new action to an automation that is Create an Issue it can not be turned on anymore.
You should try the following solution
https://confluence.atlassian.com/automation/upgrading-to-automation-for-jira-7-3-1055951956.html > The part 5 is a prerequisite when upgrading.
I experienced the same problem and this have fixed my problem
The support helped a lot on this one to be perfectly honest and I hope it could help.
Hi Chris - Welcome to the Atlassian Community!
Can you share a screen shot of your Rule Details page?
Does this Rule get called from another rule possibly? If so, check the box on the Details page.
Be sure to save and publish the Rule.
I just made this new so it should not be called by anything else.
The only things I can think of are to change the Actor to Automation For Jira to see if this has any effect.
And to click the Allow Rule Trigger box - again, just to see what happens.
Any time I try to make any changes I get "an unknown error occurred. Please reload and try again" no matter what I do. Where can I view this error?
Yes, if I try to turn it off or on I get that error. And if I go into it to make changes i get that error
That sounds like you need to go ahead and submit a ticket to Atlassian:
Hello, I have the same problem...And I just realized it is not linked to the automation I just created. It also affects "old" automation... No automation can be updated.
I created an issue to Atlassian Support
Is this issue resolved?
I am also facing same issue. I just changed "Who can edit this rule" to private means I can only edit. After this change, I am facing this issue. Its not allowing to edit the rule or disable the rule.
Many Thanks
I have exact same issue as Kiran.
It is reliably reproducible after changing "Who can edit this rule".
I cannot even delete it or disable, so it is polluting my list of automation rules.
This could be a critical problem if the trigger is automatic and not desired anymore.
Sadly we could never get this to work, instead we upgraded to cloud and this fixed all our issues
It got magically fixed for me.
Not sure how or whether it was an upgrade, since I am not an admin.
