Hi
Can someone mention the steps on how to automate the Jira to add comemnts on every issue that is aged more than 4 weeks
Hi @Preem Prakassh Dayaal ~ here's a similar rule: https://www.atlassian.com/software/jira/automation-template-library#/rule/9918920. You would need to replace the "Send email" action, with a "Comment on issue" action...
Adding to Laurie's answer...
Please consider what you want to happen after an issue has been commented upon by such a rule.
For example, do you want additional comments added every day the issue is stuck/unchanged...or only comment once per check...or something else. What you decide will help you to modify the JQL for the trigger for the rule.
