Hello!
I have an issue with the following rule. I want to subtract 'Valoare încasata €' (collected amount) out of 'valoarea facturata €'(billed value) and put the result in 'Rest de plata' ( Amount due).
Everything seems to work fine as the audit log suggests
but still the result it is not shown in the Amount due field.
Amy ideas?
Hello @Laviniu Chis
The diff() function applies only to date/time fields.
If those are number fields you need to use the minus() function. Refer to
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-math-expressions/#Plus-Minus
