Jira Create Issue Screen Problem/Static Tabs
Hemanshu Sood
Hi All,
I have a Jira instance where I maintain 10 projects. On the create issue screen, I have created 4 custom tabs(lets call them Tab 1, Tab 2 , tab 3 and Tab 4) which have 8 fields of their own. Hence, total 32 fields distributed over 4 tabs on the create issue screen.
Today when I tried to create an issue, I faced the below issues:
1) I could only see 5 fields(from Tab 1) on the create issue screen. I could not switch tabs although I could see the other tabs. When I tried to click on Tab 2,3,4 , nothing happened.
2) After populating the fields, I could not see the final Create button on the create issue screen
3) This behavior was displayed by only 5 of my projects, although I checked the screen schemes, field configurations, all of them were ok as before i.e. fields were mapped to screens and tabs and issue types.
4) For existing tickets, when I clicked on Edit , the same behavior was displayed.
Hence Create Issue and Edit issue screen for 5 of my projects are not working although the field and screen configurations are fine.
Please help
Christopher Jaksch
July 5, 2018
Hi @Hemanshu Sood,
did you already try the *Where is my field?* function?
>> https://www.atlassian.com/blog/jira-core/jira-admins-where-is-your-field
Good luck!
Best
Chris
STAGIL
Hemanshu Sood
Hi @Christopher Jaksch , yes i did, It said the field was present on the screen, but still could not see it
Christopher Jaksch
July 5, 2018
Hi @Hemanshu Sood,
please check the context of the missing customfields.
  • Is the context of each missing customfield global or attached to specific projects?
  • Are the missing customfields attached to specific issue types not used in your projects?
Best wishes
Chris
STAGIL
