Jira Premium - how to plan dependency between two jira instances in the same organization
maciej.fojtar
February 22, 2024
In Jira Premium, in Plan feature I would like to plan dependencies between issues (epics) for two jira instances that are in the same organization.
Currently I can only link issues but they are not displayed in dependencies view
Matthias Gaiser _K15t_
Hi @maciej.fojtar
as far as I know, you can only plan in issues from all projects within one instance. So, natively you can't include issues from other instances.
However, you can use marketplace apps to accomplish this. An issue sync app enables you to synchronize issues between Jira instances. So, you could sync the issues of the other instance (bidirectionally) and use the planning capabilities in your main Jira instance.
Would that work?
Matthias.
PS: I'm part of the team behind one of these issue sync apps, Backbone Issue Sync.
