Hi, since we made some changes in our Jira Workflow our story number (e.g. AB - 204) is not getting crossed out after we change the status to "done".
I cant find the right setting to undo that change. Maybe you can help me with that issue.
Thank you so much already :)
You will need to set the resolution field in your workflow.
Check out the below for more information
https://support.atlassian.com/jira-cloud-administration/docs/work-with-issue-workflows/
Using a post function you can update the field with the resolution
https://support.atlassian.com/jira-cloud-administration/docs/configure-advanced-issue-workflows/
thank you so much for the quick reply, ill try that :)
