I can't see Delete, Move, Split under Action when I try to modify worklog.
I have Jira and Tempo admin permition.
I use IE 9.0
Is my Tempo setting incorrect?
Hi Vadim,
Can you inform us about the version of Tempo Timesheets you are using.
Can you confirm that you have the "Delete Own Worklogs" or "Delete All Worklogs" in the Project permissions ( you need this for every project that you want to delete, move or split worklogs in).
Kind regards
Susanne
