No automation is running properly, some throw strange errors such as "Issue event trigger could not retrieve this issue for further processing" some others run "successfully" but actually do not do what the automation is supposed to do, and I can't even run manual trigger events since I get errors like "Oops we ran into a problem. There was a problem and we couldn't run the automation "{0}""
Anyone else having problems with automation right now? Status page seems fine.
Hi @Ozan Gürleyen
If still not solved - u have to remove separator dot from userinputs variable name.
For example: {{userInputs.issuetype}} instead of {{userInputs.issue.type}}
We randomly get this error, but the automation seems to go through anyway. Should we worry?
This is a very old thread, and recommend creating a new question to ensure the maximum number of people see it, possibly including a link back to this older one.
When you create you new question, please include the following for context:
Having a similar problem today
There seem to be some weird issues (that is a technical term) going on with some apps in general (not loading/throwing errors)
As Automation essentially also is an app that could be related.
Not clear yet on what's going on tho
I'm facing it today. When running manual trigger events since I get errors like "Oops we ran into a problem. There was a problem and we couldn't run the automation "{0}""
