Jira locked, did not start, some problem with plugin
vladimir May 9, 2016
Dear team, after restart of computer JIRA does not start anymore saying that it is locked.
I see that there is problem with plugins but:
  1. when I stop JIRA services, lock file dissappear, I do not need to delete it, when I start service, it locks JIRA again
  2. corrupted cache of plugins, you wrote that starting JIRA will recreat cache again, but this does not help as well
Please can you advice?
Vladimir
Nic Brough -Adaptavist-
May 9, 2016
The lock file is there to stop you trying to start two copies of JIRA using the same home directory.  The lock file should be there when JIRA is running and it should be detected by a second or further JIRA and they should refuse to start.
If this is locking JIRA as it starts, then you need to read the log file to find out what the reason for it locking it.  Look for atlassian-jira.log in jira-home/log
crf
May 9, 2016
Just to further clarify what Nic is telling you, the lock file is not in any way related to JIRA being "locked" – this is just an unfortunate coincidence in the names of things.  JIRA performs certain checks upon startup to ensure that everything looks like it's ok.  It wants to make sure, for example, that it can access the files that it needs to, can contact the database, and finds certain data in the database that it always expects to be there.  If anything goes wrong, then it shuts itself down and prevents you from doing anything to make sure that no harm is done.  This is what "JIRA is locked" means – that these sanity checks failed and JIRA cannot safely start.
As Nic said, the proper place for hunting down the problem is in the atlassian-jira.log file.  If you do not understand what the log file says, or do understand the problem but not how to fix it, then you should contact support, as fixing the problem may require information from your system that you probably wouldn't want to share with the general public.
Like a0703454 likes this
May 10, 2016
dear all
I will gladly share any information which may help you to help me. Please let me know which information may help.
Vladimir
crf
May 9, 2016
As Nic and I both indicated in his answer, you need to look at atlassian-jira.log.  Nobody is going to be able to help you without knowing the errors that were reported in that file.
vladimir May 10, 2016
thanks a lot, latest start log is below
JIRA starting...
2016-05-09 21:31:41,336 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Environment _____________________________
JIRA Build : 6.2.3#6260-sha1:63ef1d6dac3f4f4d7db4c1effd405ba38ccdc558
Build Date : Tue Apr 15 00:00:00 CEST 2014
JIRA Installation Type : Standalone
Application Server : Apache Tomcat/7.0.47 - Servlet API 3.0
Java Version : 1.7.0_25 - Oracle Corporation
Current Working Directory : c:\Program Files\Atlassian\JIRA
Maximum Allowable Memory : 682MB
Total Memory : 432MB
Free Memory : 173MB
Used Memory : 259MB
Memory Pool: Code Cache : Code Cache: init = 2555904(2496K) used = 2230720(2178K) committed = 2555904(2496K) max = 50331648(49152K)
Memory Pool: PS Eden Space : PS Eden Space: init = 100663296(98304K) used = 94879384(92655K) committed = 106692608(104192K) max = 112197632(109568K)
Memory Pool: PS Survivor Space : PS Survivor Space: init = 16777216(16384K) used = 17577856(17165K) committed = 78774272(76928K) max = 78774272(76928K)
Memory Pool: PS Old Gen : PS Old Gen: init = 268435456(262144K) used = 159200472(155469K) committed = 268435456(262144K) max = 536870912(524288K)
Memory Pool: PS Perm Gen : PS Perm Gen: init = 21757952(21248K) used = 18450664(18018K) committed = 21757952(21248K) max = 402653184(393216K)
JVM Input Arguments : -XX:MaxPermSize=384m -Xms384m -Xmx768m -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory -XX:+PrintGCDateStamps -XX:-OmitStackTraceInFastThrow -Djava.util.logging.config.file=c:\Program Files\Atlassian\JIRA\conf\logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.endorsed.dirs=c:\Program Files\Atlassian\JIRA\endorsed -Dcatalina.base=c:\Program Files\Atlassian\JIRA -Dcatalina.home=c:\Program Files\Atlassian\JIRA -Djava.io.tmpdir=c:\Program Files\Atlassian\JIRA\temp
Java Compatibility Information : JIRA version = 6.2.3, Java Version = 1.7.0_25
___ Java System Properties ________________
atlassian.standalone : JIRA
awt.toolkit : sun.awt.windows.WToolkit
catalina.base : c:\Program Files\Atlassian\JIRA
catalina.home : c:\Program Files\Atlassian\JIRA
catalina.useNaming : true
common.loader : ${catalina.base}/lib,
${catalina.base}/lib/*.jar,
${catalina.home}/lib,
${catalina.home}/lib/*.jar
file.encoding : Cp1252
file.encoding.pkg : sun.io
java.awt.graphicsenv : sun.awt.Win32GraphicsEnvironment
java.awt.headless : true
java.awt.printerjob : sun.awt.windows.WPrinterJob
java.class.version : 51.0
java.home : c:\Program Files\Atlassian\JIRA\jre
java.io.tmpdir : c:\Program Files\Atlassian\JIRA\temp
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.runtime.name : Java(TM) SE Runtime Environment
java.runtime.version : 1.7.0_25-b17
java.specification.name : Java Platform API Specification
java.specification.vendor : Oracle Corporation
java.specification.version : 1.7
java.util.logging.config.file : c:\Program Files\Atlassian\JIRA\conf\logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : Oracle Corporation
java.vendor.url : http://java.oracle.com/
java.vendor.url.bug : http://bugreport.sun.com/bugreport/
java.version : 1.7.0_25
java.vm.info : mixed mode
java.vm.name : Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Oracle Corporation
java.vm.specification.version : 1.7
java.vm.vendor : Oracle Corporation
java.vm.version : 23.25-b01
mail.mime.decodeparameters : true
org.apache.catalina.startup.ContextConfig.jarsToSkip :
org.apache.catalina.startup.TldConfig.jarsToSkip : tomcat7-websocket.jar
org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
org.dom4j.factory : com.atlassian.core.xml.InterningDocumentFactory
os.arch : amd64
os.name : Windows XP
os.version : 5.2
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.tomcat.,
org.apache.jasper.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.tomcat.,
org.apache.jasper.
server.loader :
shared.loader :
sun.arch.data.model : 64
sun.boot.library.path : c:\Program Files\Atlassian\JIRA\jre\bin
sun.cpu.endian : little
sun.cpu.isalist : amd64
sun.desktop : windows
sun.io.unicode.encoding : UnicodeLittle
sun.java.command : org.apache.catalina.startup.Bootstrap start
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : Cp1252
sun.management.compiler : HotSpot 64-Bit Tiered Compilers
sun.os.patch.level : Service Pack 2
tomcat.util.buf.StringCache.byte.enabled : true
tomcat.util.scan.DefaultJarScanner.jarsToSkip : bootstrap.jar,
commons-daemon.jar,
tomcat-juli.jar,
annotations-api.jar,
el-api.jar,
jsp-api.jar,
servlet-api.jar,
websocket-api.jar,
catalina.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-tribes.jar,
jasper.jar,
jasper-el.jar,
ecj-*.jar,
tomcat-api.jar,
tomcat-util.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-jni.jar,
tomcat-spdy.jar,
tomcat-i18n-en.jar,
tomcat-i18n-es.jar,
tomcat-i18n-fr.jar,
tomcat-i18n-ja.jar,
tomcat-juli-adapters.jar,
catalina-jmx-remote.jar,
catalina-ws.jar,
tomcat-jdbc.jar,
tools.jar,
commons-beanutils*.jar,
commons-codec*.jar,
commons-collections*.jar,
commons-dbcp*.jar,
commons-digester*.jar,
commons-fileupload*.jar,
commons-httpclient*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-logging*.jar,
commons-math*.jar,
commons-pool*.jar,
jstl.jar,
geronimo-spec-jaxrpc*.jar,
wsdl4j*.jar,
ant.jar,
ant-junit*.jar,
aspectj*.jar,
jmx.jar,
h2*.jar,
hibernate*.jar,
httpclient*.jar,
jmx-tools.jar,
jta*.jar,
log4j.jar,
log4j-1*.jar,
mail*.jar,
slf4j*.jar,
xercesImpl.jar,
xmlParserAPIs.jar,
xml-apis.jar,
junit.jar,
junit-*.jar,
hamcrest*.jar,
org.hamcrest*.jar,
ant-launcher.jar
user.country : US
user.dir : c:\Program Files\Atlassian\JIRA
user.home : C:\Documents and Settings\vladimir.buzalka.BUZALKA
user.language : en
user.name : vladimir.buzalka
user.script :
user.timezone : Europe/Prague
user.variant :
2016-05-09 21:31:42,180 localhost-startStop-1 INFO [atlassian.jira.startup.JiraHomeStartupCheck] The jira.home directory 'C:\Program Files\Atlassian\Application Data\JIRA' is validated and locked for exclusive use by this instance.
2016-05-09 21:31:42,195 localhost-startStop-1 INFO [jira.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2016-05-09 21:31:42,351 localhost-startStop-1 WARN [atlassian.jira.startup.ChecklistLauncher] Setting an unset default variable "plugin.webresource.batching.off" to: false
2016-05-09 21:31:42,367 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2016-05-09 21:31:42,398 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
2016-05-09 21:31:42,508 localhost-startStop-1 INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Database Checklist Launcher
2016-05-09 21:31:46,851 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Name is Microsoft SQL Server
2016-05-09 21:31:46,851 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Version is 09.00.5069
2016-05-09 21:31:46,851 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Name is jTDS Type 4 JDBC Driver for MS SQL Server and Sybase
2016-05-09 21:31:46,851 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Version is 1.2.4
2016-05-09 21:31:50,679 localhost-startStop-1 INFO [atlassian.jira.startup.DatabaseChecklistLauncher] JIRA database startup checks completed successfully.
2016-05-09 21:31:50,679 localhost-startStop-1 INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Post database-configuration launchers
2016-05-09 21:31:55,178 localhost-startStop-1 INFO [jira.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2016-05-09 21:31:59,381 localhost-startStop-1 INFO [atlassian.jira.startup.DatabaseLauncher] Database transactions enabled: true
2016-05-09 21:31:59,444 localhost-startStop-1 INFO [atlassian.jira.startup.DatabaseLauncher] Using JIRA's default for database transaction isolation level: 2
2016-05-09 21:31:59,678 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
Database configuration OK
___ Database Configuration ________________
Loading entityengine.xml from : file:/C:/Program%20Files/Atlassian/JIRA/atlassian-jira/WEB-INF/classes/entityengine.xml
Entity model field type name : mssql
Entity model schema name : dbo
Database Version : Microsoft SQL Server - 09.00.5069
Database Driver : jTDS Type 4 JDBC Driver for MS SQL Server and Sybase - 1.2.4
Database URL : jdbc:jtds:sqlserver://192.168.0.1:1433/jira
Database JDBC config : mssql jdbc:jtds:sqlserver://192.168.0.1:1433/jira
2016-05-09 21:31:59,725 localhost-startStop-1 INFO [atlassian.jira.startup.ClusteringChecklistLauncher] JIRA clustering startup checks completed successfully.
2016-05-09 21:31:59,850 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Starting the JIRA Plugin System _________________
2016-05-09 21:31:59,865 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Initialising the plugin system
2016-05-09 21:33:32,482 ThreadPoolAsyncTaskExecutor::Thread 4 WARN [org.springframework.beans.TypeConverterDelegate] PropertyEditor [com.sun.beans.editors.EnumEditor] found through deprecated global PropertyEditorManager fallback - consider using a more isolated form of registration, e.g. on the BeanWrapper/BeanFactory!
2016-05-09 21:33:43,449 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Name is Microsoft SQL Server
2016-05-09 21:33:43,449 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Version is 09.00.5069
2016-05-09 21:33:43,449 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Name is jTDS Type 4 JDBC Driver for MS SQL Server and Sybase
2016-05-09 21:33:43,449 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Version is 1.2.4
2016-05-09 21:33:46,840 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.administration.atlassian-admin-quicksearch-jira, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:33:46,902 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.administration.atlassian-admin-quicksearch-jira], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.net.RequestFactory)] (from bean [&sal-request-factory-import])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.administration.atlassian-admin-quicksearch-jira' has timed out
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
2016-05-09 21:33:46,918 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&sal-request-factory-import' for plugin 'com.atlassian.administration.atlassian-admin-quicksearch-jira' with filter (objectClass=com.atlassian.sal.api.net.RequestFactory)
2016-05-09 21:33:46,996 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.administration.atlassian-admin-quicksearch-jira
2016-05-09 21:33:47,012 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.administration.atlassian-admin-quicksearch-jira, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:33:48,496 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.applinks.plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:33:48,496 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.applinks.plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.net.RequestFactory)] (from bean [&requestFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.applinks.plugin' has timed out
2016-05-09 21:33:48,793 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&requestFactory' for plugin 'com.atlassian.applinks.applinks-plugin' with filter (objectClass=com.atlassian.sal.api.net.RequestFactory)
2016-05-09 21:33:48,793 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.applinks.applinks-plugin
2016-05-09 21:33:49,027 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.applinks.plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:33:51,355 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Name is Microsoft SQL Server
2016-05-09 21:33:51,371 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Version is 09.00.5069
2016-05-09 21:33:51,371 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Name is jTDS Type 4 JDBC Driver for MS SQL Server and Sybase
2016-05-09 21:33:51,371 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Version is 1.2.4
2016-05-09 21:33:53,855 ThreadPoolAsyncTaskExecutor::Thread 17 WARN [atlassian.analytics.client.EventSender] Unable to open connection to analytics server. Event transmission disabled. analytics
2016-05-09 21:33:55,480 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:33:55,589 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.collector.plugin.jira-issue-collector-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' has timed out
2016-05-09 21:33:55,605 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2016-05-09 21:33:55,636 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2016-05-09 21:33:56,636 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.collector.plugin.jira-issue-collector-plugin
2016-05-09 21:33:57,183 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.collector.plugin.jira-issue-collector-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:33:57,386 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.gadgets-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:33:57,386 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.gadgets-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.plugins.whitelist.OutboundWhitelist)] (from bean [&outboundWhitelist]), Dependency on [(objectClass=com.atlassian.plugins.whitelist.WhitelistService)] (from bean [&externalWhitelistService]), Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.dashboard.DashboardService)] (from bean [&dashboardService]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.gadgets-plugin' has timed out
2016-05-09 21:33:57,464 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&outboundWhitelist' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.plugins.whitelist.OutboundWhitelist)
2016-05-09 21:33:57,464 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&externalWhitelistService' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.plugins.whitelist.WhitelistService)
2016-05-09 21:33:57,464 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2016-05-09 21:33:57,464 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&dashboardService' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.dashboard.DashboardService)
2016-05-09 21:33:57,464 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.jira.gadgets' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2016-05-09 21:33:57,464 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.gadgets
2016-05-09 21:33:57,479 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.gadgets-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:33:58,089 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.header-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:33:58,245 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.header-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&applicationLinkService])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.header-plugin' has timed out
2016-05-09 21:33:58,245 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationLinkService' for plugin 'com.atlassian.jira.jira-header-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:33:58,245 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.jira-header-plugin
2016-05-09 21:33:58,245 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.header-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:33:58,448 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-applinks-common-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:00,370 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.issue-link-applinks-common-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&application-link-service])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.issue-link-applinks-common-plugin' has timed out
2016-05-09 21:34:00,370 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.jira.jira-issue-link-applinks-common-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:00,385 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.jira-issue-link-applinks-common-plugin
2016-05-09 21:34:00,385 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-applinks-common-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:00,385 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-confluence-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:00,385 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.issue-link-confluence-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&application-link-service])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.issue-link-confluence-plugin' has timed out
2016-05-09 21:34:00,385 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.jira.jira-issue-link-confluence-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:00,385 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.jira-issue-link-confluence-plugin
2016-05-09 21:34:00,401 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-confluence-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:00,401 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-remote-jira-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:00,401 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.issue-link-remote-jira-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&application-link-service])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.issue-link-remote-jira-plugin' has timed out
2016-05-09 21:34:00,573 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.jira.jira-issue-link-remote-jira-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:00,573 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.jira-issue-link-remote-jira-plugin
2016-05-09 21:34:00,588 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.issue-link-remote-jira-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:01,120 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.project-config-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:01,135 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.project-config-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&applicationLinkService])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.project-config-plugin' has timed out
2016-05-09 21:34:01,182 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationLinkService' for plugin 'com.atlassian.jira.jira-project-config-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:01,182 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.jira-project-config-plugin
2016-05-09 21:34:01,198 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.project-config-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:01,417 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.jira-quick-edit-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:01,432 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.jira-quick-edit-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.jira.rest.v2.issue.builder.BeanBuilderFactory)] (from bean [&beanBuilderFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.jira-quick-edit-plugin' has timed out
2016-05-09 21:34:01,510 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&beanBuilderFactory' for plugin 'com.atlassian.jira.jira-quick-edit-plugin' with filter (objectClass=com.atlassian.jira.rest.v2.issue.builder.BeanBuilderFactory)
2016-05-09 21:34:01,526 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.jira-quick-edit-plugin
2016-05-09 21:34:01,526 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.jira-quick-edit-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:02,088 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.view-issue-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:02,088 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.view-issue-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&application-link-service])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.view-issue-plugin' has timed out
2016-05-09 21:34:02,104 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.jira.jira-view-issue-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:02,104 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.jira-view-issue-plugin
2016-05-09 21:34:02,104 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.view-issue-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:04,666 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.jira-bamboo-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:04,666 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.plugins.jira-bamboo-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.EntityLinkService)] (from bean [&entityLinkService]), Dependency on [(objectClass=com.atlassian.applinks.spi.util.TypeAccessor)] (from bean [&typeAccessor]), Dependency on [(objectClass=com.atlassian.applinks.spi.auth.AuthenticationConfigurationManager)] (from bean [&authenticationConfigurationManager]), Dependency on [(objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)] (from bean [&linkedApplicationCapabilities]), Dependency on [(objectClass=com.atlassian.applinks.spi.link.MutatingApplicationLinkService)] (from bean [&applicationLinkService])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.plugins.jira-bamboo-plugin' has timed out
2016-05-09 21:34:04,666 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityLinkService' for plugin 'com.atlassian.jira.plugin.ext.bamboo' with filter (objectClass=com.atlassian.applinks.api.EntityLinkService)
2016-05-09 21:34:04,666 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&typeAccessor' for plugin 'com.atlassian.jira.plugin.ext.bamboo' with filter (objectClass=com.atlassian.applinks.spi.util.TypeAccessor)
2016-05-09 21:34:04,666 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&authenticationConfigurationManager' for plugin 'com.atlassian.jira.plugin.ext.bamboo' with filter (objectClass=com.atlassian.applinks.spi.auth.AuthenticationConfigurationManager)
2016-05-09 21:34:04,760 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&linkedApplicationCapabilities' for plugin 'com.atlassian.jira.plugin.ext.bamboo' with filter (objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)
2016-05-09 21:34:04,776 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationLinkService' for plugin 'com.atlassian.jira.plugin.ext.bamboo' with filter (objectClass=com.atlassian.applinks.spi.link.MutatingApplicationLinkService)
2016-05-09 21:34:04,776 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.plugin.ext.bamboo
2016-05-09 21:34:04,791 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.jira-bamboo-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:09,260 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.project-templates-plugin, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, org.swift.jira.cli, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 60 seconds remaining
2016-05-09 21:34:10,259 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.project-templates-plugin, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 59 seconds remaining
2016-05-09 21:34:11,259 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.project-templates-plugin, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 58 seconds remaining
2016-05-09 21:34:11,337 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.project-templates-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:11,337 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.plugins.project-templates-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.EntityLinkService)] (from bean [&entityLinkService])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.plugins.project-templates-plugin' has timed out
2016-05-09 21:34:11,337 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityLinkService' for plugin 'com.atlassian.jira.project-templates-plugin' with filter (objectClass=com.atlassian.applinks.api.EntityLinkService)
2016-05-09 21:34:11,337 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.project-templates-plugin
2016-05-09 21:34:11,337 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.project-templates-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:12,259 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 57 seconds remaining
2016-05-09 21:34:13,119 hipchat-plugin-tasks-executor-0 ERROR [atlassian.activeobjects.osgi.ActiveObjectsServiceFactory] Didn't find any configuration service for bundle com.atlassian.plugins.base-hipchat-integration-plugin-api nor any entities scanning for default AO packages.
2016-05-09 21:34:13,259 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 56 seconds remaining
2016-05-09 21:34:14,275 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 54 seconds remaining
2016-05-09 21:34:15,275 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 53 seconds remaining
2016-05-09 21:34:16,274 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 52 seconds remaining
2016-05-09 21:34:17,274 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 51 seconds remaining
2016-05-09 21:34:17,977 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:17,977 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.spi.link.MutatingApplicationLinkService)] (from bean [&applicationLinkService])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin' has timed out
2016-05-09 21:34:17,977 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationLinkService' for plugin 'com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin' with filter (objectClass=com.atlassian.applinks.spi.link.MutatingApplicationLinkService)
2016-05-09 21:34:17,977 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin
2016-05-09 21:34:17,977 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:18,274 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 50 seconds remaining
2016-05-09 21:34:18,805 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.jira-fisheye-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:18,805 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.plugins.jira-fisheye-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.spi.link.MutatingEntityLinkService)] (from bean [&entityLinkService]), Dependency on [(objectClass=com.atlassian.applinks.spi.manifest.ManifestRetriever)] (from bean [&manifestRetriever]), Dependency on [(objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)] (from bean [&linkedApplicationCapabilities]), Dependency on [(objectClass=com.atlassian.applinks.spi.util.TypeAccessor)] (from bean [&typeAccessor]), Dependency on [(objectClass=com.atlassian.applinks.spi.auth.AuthenticationConfigurationManager)] (from bean [&authenticationConfigurationManager]), Dependency on [(objectClass=com.atlassian.applinks.spi.link.MutatingApplicationLinkService)] (from bean [&mutatingApplicationLinkService]), Dependency on [(objectClass=com.atlassian.applinks.spi.link.EntityLinkBuilderFactory)] (from bean [&entityBuilderFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.plugins.jira-fisheye-plugin' has timed out
2016-05-09 21:34:18,805 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityLinkService' for plugin 'com.atlassian.jirafisheyeplugin' with filter (objectClass=com.atlassian.applinks.spi.link.MutatingEntityLinkService)
2016-05-09 21:34:18,805 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&manifestRetriever' for plugin 'com.atlassian.jirafisheyeplugin' with filter (objectClass=com.atlassian.applinks.spi.manifest.ManifestRetriever)
2016-05-09 21:34:18,805 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&linkedApplicationCapabilities' for plugin 'com.atlassian.jirafisheyeplugin' with filter (objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)
2016-05-09 21:34:18,805 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&typeAccessor' for plugin 'com.atlassian.jirafisheyeplugin' with filter (objectClass=com.atlassian.applinks.spi.util.TypeAccessor)
2016-05-09 21:34:18,805 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&authenticationConfigurationManager' for plugin 'com.atlassian.jirafisheyeplugin' with filter (objectClass=com.atlassian.applinks.spi.auth.AuthenticationConfigurationManager)
2016-05-09 21:34:18,805 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&mutatingApplicationLinkService' for plugin 'com.atlassian.jirafisheyeplugin' with filter (objectClass=com.atlassian.applinks.spi.link.MutatingApplicationLinkService)
2016-05-09 21:34:18,805 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityBuilderFactory' for plugin 'com.atlassian.jirafisheyeplugin' with filter (objectClass=com.atlassian.applinks.spi.link.EntityLinkBuilderFactory)
2016-05-09 21:34:18,805 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jirafisheyeplugin
2016-05-09 21:34:18,805 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.jira-fisheye-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:19,274 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 49 seconds remaining
2016-05-09 21:34:20,274 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.mywork.mywork-common-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 48 seconds remaining
2016-05-09 21:34:21,196 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.mywork.common-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:21,196 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.mywork.common-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&application-link-service]), Dependency on [(objectClass=com.atlassian.applinks.spi.auth.AuthenticationConfigurationManager)] (from bean [&authenticationConfigurationManager])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.mywork.common-plugin' has timed out
2016-05-09 21:34:21,196 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.mywork.mywork-common-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:21,196 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&authenticationConfigurationManager' for plugin 'com.atlassian.mywork.mywork-common-plugin' with filter (objectClass=com.atlassian.applinks.spi.auth.AuthenticationConfigurationManager)
2016-05-09 21:34:21,196 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.mywork.mywork-common-plugin
2016-05-09 21:34:21,196 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.mywork.common-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:21,290 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 47 seconds remaining
2016-05-09 21:34:22,290 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 46 seconds remaining
2016-05-09 21:34:23,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 45 seconds remaining
2016-05-09 21:34:24,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.mywork.mywork-jira-provider-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 44 seconds remaining
2016-05-09 21:34:24,664 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.mywork.jira-provider-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:24,664 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.mywork.jira-provider-plugin], unsatisfied dependencies: Dependency on [(&(objectClass=com.atlassian.mywork.service.NotificationService)(type=delegator))] (from bean [&notificationService]), Dependency on [(objectClass=com.atlassian.mywork.service.HostService)] (from bean [&hostService]), Dependency on [(&(objectClass=com.atlassian.mywork.service.TaskService)(type=delegator))] (from bean [&taskService]), Dependency on [(objectClass=com.atlassian.mywork.service.ServiceSelector)] (from bean [&serviceSelector])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.mywork.jira-provider-plugin' has timed out
2016-05-09 21:34:24,664 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&notificationService' for plugin 'com.atlassian.mywork.mywork-jira-provider-plugin' with filter (&(objectClass=com.atlassian.mywork.service.NotificationService)(type=delegator))
2016-05-09 21:34:24,664 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&hostService' for plugin 'com.atlassian.mywork.mywork-jira-provider-plugin' with filter (objectClass=com.atlassian.mywork.service.HostService)
2016-05-09 21:34:24,664 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&taskService' for plugin 'com.atlassian.mywork.mywork-jira-provider-plugin' with filter (&(objectClass=com.atlassian.mywork.service.TaskService)(type=delegator))
2016-05-09 21:34:24,664 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&serviceSelector' for plugin 'com.atlassian.mywork.mywork-jira-provider-plugin' with filter (objectClass=com.atlassian.mywork.service.ServiceSelector)
2016-05-09 21:34:24,664 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.mywork.mywork-jira-provider-plugin
2016-05-09 21:34:24,664 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.mywork.jira-provider-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:25,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 43 seconds remaining
2016-05-09 21:34:25,430 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:25,430 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.plugins.jira-bitbucket-connector-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.UserProfileAccessor)] (from bean [&userProfileAccessor])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.plugins.jira-bitbucket-connector-plugin' has timed out
2016-05-09 21:34:25,430 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userProfileAccessor' for plugin 'com.atlassian.jira.plugins.jira-bitbucket-connector-plugin' with filter (objectClass=com.atlassian.streams.spi.UserProfileAccessor)
2016-05-09 21:34:25,430 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.plugins.jira-bitbucket-connector-plugin
2016-05-09 21:34:25,430 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.jira-bitbucket-connector-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:26,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.plugins.atlassian-whitelist-api-plugin, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-nav-links-plugin, com.atlassian.plugins.atlassian-whitelist-ui-plugin, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 42 seconds remaining
2016-05-09 21:34:26,617 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.atlassian-whitelist-api-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:26,617 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.plugins.atlassian-whitelist-api-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&applicationLinkService])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.plugins.atlassian-whitelist-api-plugin' has timed out
2016-05-09 21:34:26,617 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationLinkService' for plugin 'com.atlassian.plugins.atlassian-whitelist-api-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:26,617 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.plugins.atlassian-whitelist-api-plugin
2016-05-09 21:34:26,617 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.atlassian-whitelist-api-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:26,633 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.atlassian-nav-links-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:26,633 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.plugins.atlassian-nav-links-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.applinks.spi.link.MutatingEntityLinkService)] (from bean [&mutatingEntityLinkService]), Dependency on [(objectClass=com.atlassian.applinks.spi.util.TypeAccessor)] (from bean [&typeAccessor]), Dependency on [(objectClass=com.atlassian.plugins.navlink.spi.ProjectPermissionManager)] (from bean [&projectPermissionManager]), Dependency on [(objectClass=com.atlassian.plugins.navlink.spi.ProjectManager)] (from bean [&projectManager]), Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&app-link-service]), Dependency on [(objectClass=com.atlassian.plugins.navlink.spi.weights.ApplicationWeights)] (from bean [&weights])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.plugins.atlassian-nav-links-plugin' has timed out
2016-05-09 21:34:26,633 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&mutatingEntityLinkService' for plugin 'com.atlassian.plugins.atlassian-nav-links-plugin' with filter (objectClass=com.atlassian.applinks.spi.link.MutatingEntityLinkService)
2016-05-09 21:34:26,633 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&typeAccessor' for plugin 'com.atlassian.plugins.atlassian-nav-links-plugin' with filter (objectClass=com.atlassian.applinks.spi.util.TypeAccessor)
2016-05-09 21:34:26,633 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&projectPermissionManager' for plugin 'com.atlassian.plugins.atlassian-nav-links-plugin' with filter (objectClass=com.atlassian.plugins.navlink.spi.ProjectPermissionManager)
2016-05-09 21:34:26,633 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&projectManager' for plugin 'com.atlassian.plugins.atlassian-nav-links-plugin' with filter (objectClass=com.atlassian.plugins.navlink.spi.ProjectManager)
2016-05-09 21:34:26,633 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&app-link-service' for plugin 'com.atlassian.plugins.atlassian-nav-links-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:26,633 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&weights' for plugin 'com.atlassian.plugins.atlassian-nav-links-plugin' with filter (objectClass=com.atlassian.plugins.navlink.spi.weights.ApplicationWeights)
2016-05-09 21:34:26,633 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.plugins.atlassian-nav-links-plugin
2016-05-09 21:34:26,633 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.atlassian-nav-links-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:26,680 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.atlassian-whitelist-ui-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:26,680 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.plugins.atlassian-whitelist-ui-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.plugins.whitelist.InboundWhitelist)] (from bean [&inboundWhitelist]), Dependency on [(objectClass=com.atlassian.plugins.whitelist.OutboundWhitelist)] (from bean [&outboundWhitelist]), Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&applicationLinkService]), Dependency on [(objectClass=com.atlassian.plugins.whitelist.WhitelistService)] (from bean [&whitelistService])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.plugins.atlassian-whitelist-ui-plugin' has timed out
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
2016-05-09 21:34:26,680 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&inboundWhitelist' for plugin 'com.atlassian.plugins.atlassian-whitelist-ui-plugin' with filter (objectClass=com.atlassian.plugins.whitelist.InboundWhitelist)
2016-05-09 21:34:26,680 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&outboundWhitelist' for plugin 'com.atlassian.plugins.atlassian-whitelist-ui-plugin' with filter (objectClass=com.atlassian.plugins.whitelist.OutboundWhitelist)
2016-05-09 21:34:26,680 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationLinkService' for plugin 'com.atlassian.plugins.atlassian-whitelist-ui-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:26,680 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&whitelistService' for plugin 'com.atlassian.plugins.atlassian-whitelist-ui-plugin' with filter (objectClass=com.atlassian.plugins.whitelist.WhitelistService)
2016-05-09 21:34:26,680 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.plugins.atlassian-whitelist-ui-plugin
2016-05-09 21:34:26,680 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.atlassian-whitelist-ui-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:27,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.plugins.jira-remote-link-aggregator-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 41 seconds remaining
2016-05-09 21:34:28,133 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.jira-remote-link-aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:28,133 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.plugins.jira-remote-link-aggregator-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)] (from bean [&linked-application-capabilities]), Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&application-link-service])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.plugins.jira-remote-link-aggregator-plugin' has timed out
2016-05-09 21:34:28,133 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&linked-application-capabilities' for plugin 'com.atlassian.plugins.jira-remote-link-aggregator-plugin' with filter (objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)
2016-05-09 21:34:28,133 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.plugins.jira-remote-link-aggregator-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:28,133 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.plugins.jira-remote-link-aggregator-plugin
2016-05-09 21:34:28,133 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.jira-remote-link-aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:28,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 40 seconds remaining
2016-05-09 21:34:29,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.streams, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams.actions, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 39 seconds remaining
2016-05-09 21:34:29,851 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:29,851 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.aggregator-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)] (from bean [&formatPreferenceProvider]), Dependency on [(objectClass=com.atlassian.applinks.api.EntityLinkService)] (from bean [&entityLinkService]), Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&applinkService]), Dependency on [(objectClass=com.atlassian.streams.spi.EntityResolver)] (from bean [&entityResolvers])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.aggregator-plugin' has timed out
2016-05-09 21:34:29,851 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&formatPreferenceProvider' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)
2016-05-09 21:34:29,851 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityLinkService' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.applinks.api.EntityLinkService)
2016-05-09 21:34:29,851 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applinkService' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:34:29,851 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityResolvers' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.EntityResolver)
2016-05-09 21:34:29,851 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.streams
2016-05-09 21:34:29,851 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:29,867 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:29,867 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.inline-actions-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)] (from bean [&streamsLocaleProvider])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.inline-actions-plugin' has timed out
2016-05-09 21:34:29,867 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsLocaleProvider' for plugin 'com.atlassian.streams.actions' with filter (objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)
2016-05-09 21:34:29,867 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.streams.actions
2016-05-09 21:34:29,867 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:30,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.streams.streams-jira-plugin, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 38 seconds remaining
2016-05-09 21:34:30,898 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:30,898 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.jira-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.jira-plugin' has timed out
2016-05-09 21:34:30,898 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2016-05-09 21:34:30,898 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2016-05-09 21:34:30,898 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.streams.streams-jira-plugin
2016-05-09 21:34:30,898 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:31,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 37 seconds remaining
2016-05-09 21:34:32,289 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory, com.atlassian.streams.streams-thirdparty-plugin], 36 seconds remaining
2016-05-09 21:34:32,820 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2016-05-09 21:34:32,820 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.thirdparty-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.UserProfileAccessor)] (from bean [&userProfileAccessor])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.thirdparty-plugin' has timed out
2016-05-09 21:34:32,820 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userProfileAccessor' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.streams.spi.UserProfileAccessor)
2016-05-09 21:34:32,820 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.streams.streams-thirdparty-plugin
2016-05-09 21:34:32,820 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml))
2016-05-09 21:34:33,288 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 35 seconds remaining
2016-05-09 21:34:34,288 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 34 seconds remaining
2016-05-09 21:34:35,288 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 33 seconds remaining
2016-05-09 21:34:36,288 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 32 seconds remaining
2016-05-09 21:34:37,304 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 31 seconds remaining
2016-05-09 21:34:38,304 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 30 seconds remaining
2016-05-09 21:34:39,304 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 29 seconds remaining
2016-05-09 21:34:40,303 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 28 seconds remaining
2016-05-09 21:34:41,303 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 27 seconds remaining
2016-05-09 21:34:42,303 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 26 seconds remaining
2016-05-09 21:34:43,303 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 25 seconds remaining
2016-05-09 21:34:44,319 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 24 seconds remaining
2016-05-09 21:34:45,319 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 23 seconds remaining
2016-05-09 21:34:46,318 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 22 seconds remaining
2016-05-09 21:34:47,318 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 21 seconds remaining
2016-05-09 21:34:48,334 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 20 seconds remaining
2016-05-09 21:34:49,334 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 19 seconds remaining
2016-05-09 21:34:50,334 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 18 seconds remaining
2016-05-09 21:34:51,334 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 17 seconds remaining
2016-05-09 21:34:52,334 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 16 seconds remaining
2016-05-09 21:34:53,349 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 15 seconds remaining
2016-05-09 21:34:54,349 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 14 seconds remaining
2016-05-09 21:34:55,349 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 13 seconds remaining
2016-05-09 21:34:56,349 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 12 seconds remaining
2016-05-09 21:34:57,349 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 11 seconds remaining
2016-05-09 21:34:58,364 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 10 seconds remaining
2016-05-09 21:34:59,380 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 9 seconds remaining
2016-05-09 21:35:00,380 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 8 seconds remaining
2016-05-09 21:35:01,380 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 7 seconds remaining
2016-05-09 21:35:02,379 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 6 seconds remaining
2016-05-09 21:35:03,379 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 5 seconds remaining
2016-05-09 21:35:04,379 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 4 seconds remaining
2016-05-09 21:35:05,379 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 3 seconds remaining
2016-05-09 21:35:06,379 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 2 seconds remaining
2016-05-09 21:35:07,379 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 1 seconds remaining
2016-05-09 21:35:08,379 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.plugins.atlassian-project-creation-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.dashboard, com.atlassian.plugins.atlassian-awareness-capability, com.atlassian.jira.plugins.jira-development-integration-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.gadgets.embedded, com.atlassian.labs.hipchat.hipchat-for-jira-plugin, com.atlassian.gadgets.directory], 0 seconds remaining
2016-05-09 21:35:09,379 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.plugins.atlassian-project-creation-plugin
2016-05-09 21:35:09,379 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.plugins.atlassian-project-creation-plugin' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:35:09,379 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entity-link-builder-factory' for plugin 'com.atlassian.plugins.atlassian-project-creation-plugin' with filter (objectClass=com.atlassian.applinks.spi.link.EntityLinkBuilderFactory)
2016-05-09 21:35:09,379 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&type-accessor' for plugin 'com.atlassian.plugins.atlassian-project-creation-plugin' with filter (objectClass=com.atlassian.applinks.spi.util.TypeAccessor)
2016-05-09 21:35:09,379 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&mutating-entity-link-service' for plugin 'com.atlassian.plugins.atlassian-project-creation-plugin' with filter (objectClass=com.atlassian.applinks.spi.link.MutatingEntityLinkService)
2016-05-09 21:35:09,379 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&custom-content-links' for plugin 'com.atlassian.plugins.atlassian-project-creation-plugin' with filter (objectClass=com.atlassian.plugins.navlink.producer.contentlinks.customcontentlink.CustomContentLinkService)
2016-05-09 21:35:09,394 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.gadgets.opensocial
2016-05-09 21:35:09,394 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&appLinksService' for plugin 'com.atlassian.gadgets.opensocial' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:35:09,394 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.gadgets.dashboard
2016-05-09 21:35:09,394 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (&(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory))
2016-05-09 21:35:09,394 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecUrlChecker' for plugin 'com.atlassian.gadgets.dashboard' with filter (&(objectClass=com.atlassian.gadgets.GadgetSpecUrlChecker)(objectClass=com.atlassian.gadgets.GadgetSpecUrlChecker))
2016-05-09 21:35:09,394 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (&(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory))
2016-05-09 21:35:09,394 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&renderedGadgetUriBuilder' for plugin 'com.atlassian.gadgets.dashboard' with filter (&(objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder)(objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder))
2016-05-09 21:35:09,394 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.plugins.atlassian-awareness-capability
2016-05-09 21:35:09,394 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&application-link-service' for plugin 'com.atlassian.plugins.atlassian-awareness-capability' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
2016-05-09 21:35:09,410 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.jira.plugins.jira-development-integration-plugin
2016-05-09 21:35:09,410 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationLinkService' for plugin 'com.atlassian.jira.plugins.jira-development-integration-plugin' with filter (&(objectClass=com.atlassian.applinks.api.ApplicationLinkService)(objectClass=com.atlassian.applinks.api.ApplicationLinkService))
2016-05-09 21:35:09,410 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&remoteNavigationLinkService' for plugin 'com.atlassian.jira.plugins.jira-development-integration-plugin' with filter (&(objectClass=com.atlassian.plugins.navlink.consumer.menu.services.RemoteNavigationLinkService)(objectClass=com.atlassian.plugins.navlink.consumer.menu.services.RemoteNavigationLinkService))
2016-05-09 21:35:09,410 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&linkedApplicationCapabilities' for plugin 'com.atlassian.jira.plugins.jira-development-integration-plugin' with filter (&(objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)(objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities))
2016-05-09 21:35:09,410 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.gadgets.oauth.serviceprovider
2016-05-09 21:35:09,410 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (&(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory))
2016-05-09 21:35:09,426 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (&(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory))
2016-05-09 21:35:09,426 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.gadgets.embedded
2016-05-09 21:35:09,426 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (&(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory))
2016-05-09 21:35:09,426 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&securityTokenFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (&(objectClass=com.atlassian.gadgets.view.SecurityTokenFactory)(objectClass=com.atlassian.gadgets.view.SecurityTokenFactory))
2016-05-09 21:35:09,426 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.labs.hipchat.hipchat-for-jira-plugin
2016-05-09 21:35:09,426 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&projectConfigRequestCache' for plugin 'com.atlassian.labs.hipchat.hipchat-for-jira-plugin' with filter (objectClass=com.atlassian.jira.projectconfig.util.ProjectConfigRequestCache)
2016-05-09 21:35:09,441 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.gadgets.directory
2016-05-09 21:35:09,441 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.directory' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2016-05-09 21:35:09,441 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&subscribedGadgetFeedStore' for plugin 'com.atlassian.gadgets.directory' with filter (&(objectClass=com.atlassian.gadgets.directory.spi.SubscribedGadgetFeedStore)(objectClass=com.atlassian.gadgets.directory.spi.SubscribedGadgetFeedStore))
2016-05-09 21:35:09,441 localhost-startStop-1 ERROR [atlassian.plugin.manager.PluginEnabler] Unable to start the following plugins due to timeout while waiting for plugin to enable: com.atlassian.plugins.atlassian-project-creation-plugin,com.atlassian.gadgets.opensocial,com.atlassian.gadgets.dashboard,com.atlassian.plugins.atlassian-awareness-capability,com.atlassian.jira.plugins.jira-development-integration-plugin,com.atlassian.gadgets.oauth.serviceprovider,com.atlassian.gadgets.embedded,com.atlassian.labs.hipchat.hipchat-for-jira-plugin,com.atlassian.gadgets.directory
2016-05-09 21:35:09,941 localhost-startStop-1 INFO [jira.plugins.monitor.MonitoringScheduler] Scheduling metrics collector to run every 10000ms...
2016-05-09 21:35:09,941 localhost-startStop-1 INFO [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: C:\Program Files\Atlassian\Application Data\JIRA\monitor\ConnectionPoolGraph.rrd4j
2016-05-09 21:35:09,972 localhost-startStop-1 INFO [plugins.monitor.rrd4j.RrdUpdater] Reusing existing RrdDb: C:\Program Files\Atlassian\Application Data\JIRA\monitor\DatabaseReadWritesGraph.rrd4j
2016-05-09 21:35:09,988 localhost-startStop-1 INFO [jira.plugins.monitor.MonitorLauncher] Started JIRA monitoring
2016-05-09 21:35:12,160 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Plugin system started in 0:03:12.295
2016-05-09 21:35:12,191 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Plugin System Started _________________
2016-05-09 21:35:12,566 localhost-startStop-1 INFO [jira.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2016-05-09 21:35:12,582 localhost-startStop-1 INFO [jira.instrumentation.external.DatabaseExternalGauges] Installing DBCP monitoring instruments: DatabaseExternalGauges.JiraDbcpInstruments[instruments=[DBCP_MAX, DBCP_ACTIVE, DBCP_IDLE],objectName=com.atlassian.jira:name=BasicDataSource]
2016-05-09 21:35:13,253 localhost-startStop-1 INFO [atlassian.jira.upgrade.ConsistencyCheckImpl] Checking JIRA consistency
2016-05-09 21:35:13,347 localhost-startStop-1 INFO [service.services.file.AbstractMessageHandlingService$HandlerDisablementListener] Registering disablement listener for module 'com.atlassian.jira.jira-mail-plugin:createOrCommentHandler'
2016-05-09 21:35:13,425 localhost-startStop-1 INFO [atlassian.jira.upgrade.ConsistencyCheckImpl] The Server ID for this JIRA instance is: [B6GF-5K7Q-Z4M7-E5PE]
2016-05-09 21:35:14,347 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ User Directories (Ordered) ______________
INTERNAL : JIRA Internal Directory
Implementing Class : com.atlassian.crowd.directory.InternalDirectory
Allowed Operations : CREATE_GROUP,
CREATE_ROLE,
CREATE_USER,
DELETE_GROUP,
DELETE_ROLE,
DELETE_USER,
UPDATE_GROUP,
UPDATE_GROUP_ATTRIBUTE,
UPDATE_ROLE,
UPDATE_ROLE_ATTRIBUTE,
UPDATE_USER,
UPDATE_USER_ATTRIBUTE
Encryption Type : atlassian-security
Active : true
Attributes :
user_encryption_method : atlassian-security
___ Core Application Properties ___________
Version : 6.2.3
Build # : 6260
Build Date : Tue Apr 15 00:00:00 CEST 2014
Installation Type : Standalone
Server ID : B6GF-5K7Q-Z4M7-E5PE
Base URL : http://jira.buzalka.cz:8080
Default Language : English (United States)
External User Management : OFF
___ Application Properties ________________
AO_4AEACD_# : 1
AO_54307E_# : 501
AO_544E33_# : 1
AO_78C957_# : 132
AO_7A2604_# : 1
AO_E8B6CC_# : 13
HerculesScheduledScanTask.enabled : true
HerculesScheduledScanTask.recipients : vladimir.buzalka@buzalka.cz
chaperone:sd-gettingstarted:vladimir.buzalka : [".sd-queue",".sd-report","li.sd-sla",".sd-customer-admin"]
com.almworks.jira.structure.config.defaultStructurePP : 10105=102,10000=103,10108=104,10104=105
com.almworks.jira.structure.config.enabledForAllProjects : false
com.almworks.jira.structure.config.enabledForAnyone : true
com.almworks.jira.structure.config.enabledProjects :
com.almworks.jira.structure.config.enabledSubjects :
com.atlassian.activeobjects.admin.ActiveObjectsPluginToTablesMapping : null
com.atlassian.analytics.client.configuration..analytics_enabled : true
com.atlassian.analytics.client.configuration..policy_acknowledged : true
com.atlassian.crowd.embedded.admin:build : 3
com.atlassian.jira.gadgets:build : 1
com.atlassian.jira.jira-mail-plugin:build : 2
com.atlassian.jira.lookandfeel:build : 1
com.atlassian.jira.lookandfeel:customDefaultFaviconHiresURL : /images/64jira.png
com.atlassian.jira.lookandfeel:customDefaultFaviconURL : /favicon.ico
com.atlassian.jira.lookandfeel:faviconHeight : 64
com.atlassian.jira.lookandfeel:faviconWidth : 64
com.atlassian.jira.lookandfeel:isDefaultFavicon : false
com.atlassian.jira.lookandfeel:usingCustomFavicon : false
com.atlassian.jira.lookandfeel:usingCustomLogo : false
com.atlassian.jira.plugin.ext.bamboo:build : 1
com.atlassian.jira.plugins.jira-bitbucket-connector-plugin:build : 2
com.atlassian.jira.plugins.jira-importers-plugin:build : 1
com.atlassian.jira.plugins.jira-workflow-designer:build : 1
com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin:build : 2
com.atlassian.jira.project-templates-plugin:build : 2001
com.atlassian.jira.util.index.IndexingCounterManagerImpl.counterValue : 23
com.atlassian.labs.hipchat.hipchat-for-jira-plugin:build : 1
com.atlassian.plugins.atlassian-nav-links-plugin:build : 1
com.atlassian.plugins.atlassian-whitelist-api-plugin:build : 4
com.atlassian.plugins.atlassian-whitelist-api-plugin:whitelist.enabled : true
com.atlassian.plugins.custom_apps.hasCustomOrder : false
com.atlassian.sal.jira:build : 2
com.atlassian.servicedesk:build : 2
com.atlassian.upm.Sys:upm-settings:updated-upm-version : 2.13.3
com.atlassian.upm.UserSettingsStore:acceptedMpacEula:vladimir.buzalka : true
com.atlassian.upm.atlassian-universal-plugin-manager-plugin:build : 4
com.atlassian.upm.core.Sys:upm-settings:updated-upm-version : 2.18.1
com.atlassian.upm.impl.PluginSettingsPluginUpdateRequestStoreplugin-update-requests : #java.util.List
com.atlassian.upm.license.internal.impl.PluginSettingsLicenseTokenStore:license-tokens : #java.util.List
com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseR1da690ae1cbb0bfe765e48e5f20afae5 : null
com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseR339b1704e923b2280c224738f2d48ceb : null
com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseR350b224351e10595160d15cdeb0e7dab : null
com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseR5f6aa352a997b67942bb0240b6dacb13 : null
com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseR8bdca18bb1b7389d0a2d834a01247d76 : null
com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseRc070ebab8c539dd6f275aee9ebdd5c47 : null
com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseRcf4a426e9339895f2b8fb10b9ae699ac : null
com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseRepository:licenses:plugin.jep : null
com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseRfdbfad06c2f1036a60cb955d7e285d69 : #java.util.List
com.almworks.jira.plugin.jiraclient
plugin.jep
com.pyxis.greenhopper.jira
com.metainf.jira.plugin.emailissue
com.xpandit.plugins.jiraxporter
org.swift.jira.cli
com.atlassian.upm.log.PluginSettingsAuditLogService:log:upm_audit_log_v3 : #java.util.List
{"userKey":"JIRA","date":1457682213920,"i18nKey":"upm.auditLog.upm.startup","entryType":"UPM_STARTUP","params":[]}
com.atlassian.upm.mail.impl.PluginSettingsLicenseEmailStorelicense-emails_v2 : #java.util.List
com.atlassian.upm.notification.ManualUpdateRequiredNotificationServi4132bc4b6b94205656e44360bcb38069 : #java.util.List
com.atlassian.upm.request.PluginSettingsPluginRequestStore:requests:requests_v2 : #java.util.List
com.atlassian.upm:notifications:dismissal-auto.updated.plugin : #java.util.List
com.atlassian.upm:notifications:dismissal-auto.updated.upm : #java.util.List
com.atlassian.upm:notifications:dismissal-edition.mismatch : #java.util.List
com.atlassian.upm:notifications:dismissal-plugin.request : #java.util.List
com.atlassian.upm:notifications:notification-edition.mismatch : #java.util.List
com.atlassian.upm:notifications:notification-evaluation.expired : #java.util.List
com.atlassian.upm:notifications:notification-evaluation.nearlyexpired : #java.util.List
com.atlassian.upm:notifications:notification-maintenance.expired : #java.util.List
com.atlassian.upm:notifications:notification-maintenance.nearlyexpired : #java.util.List
com.atlassian.upm:notifications:notification-new.licenses : 0
com.atlassian.upm:notifications:notification-plugin.request : #java.util.List
com.atlassian.upm:notifications:notification-update : null
com.atlassian.upm:notifications:notification-updated.licenses : 1
com.pyxis.greenhopper.jira:build : 42
com.thepluginpeople.jemh.adhoc:SYSTEM_DEFAULT : null
com.xpandit.plugins.jiraxporter:build : 100033100
dvcs.connector.bitbucket.url : https://bitbucket.org
dvcs.connector.github.url : https://github.com
google.site.verification.key :
jira-header-plugin.studio-tab-migration-complete : migrated
jira.admin.gadget.task.list.enabled : true
jira.ajax.autocomplete.issuepicker.enabled : true
jira.ajax.autocomplete.labelsuggestion.limit : 20
jira.ajax.autocomplete.limit : 20
jira.alertheader.visibility : private
jira.assignee.change.is.sent.to.both.parties : true
jira.attachment.allow.zip.support : true
jira.attachment.do.not.expand.as.zip.extensions.list : docx, docm, dotx, dotm, xlsx, xlsm, xltx, xltm, xlsb, xlam, pptx, pptm, potx, potm, ppam, ppsx, ppsm, sldx, sldm, thmx, odt, odp, ods, odg, odb, odf, ott, otp, ots, otg, odm, sxw, stw, sxc, stc, sxi, sti, sxd, std, sxg
jira.attachment.download.mime.sniffing.workaround : workaround
jira.attachment.number.of.zip.entries : 30
jira.autoexport : true
jira.avatar.default.id : 10011
jira.avatar.megapixels : 10
jira.avatar.user.anonymous.id : 10123
jira.avatar.user.default.id : 10122
jira.baseurl : http://jira.buzalka.cz:8080
jira.browser.unsupported.warnings.disabled : false
jira.bulk.edit.limit.issue.count : 1000
jira.chart.days.previous.limit.daily : 300
jira.chart.days.previous.limit.hourly : 10
jira.chart.days.previous.limit.monthly : 7500
jira.chart.days.previous.limit.quarterly : 22500
jira.chart.days.previous.limit.weekly : 1750
jira.chart.days.previous.limit.yearly : 36500
jira.clone.linktype.name : Cloners
jira.clone.prefix : CLONE -
jira.comment.collapsing.minimum.hidden : 4
jira.comment.level.visibility.groups : false
jira.constant.default.priority : 3
jira.constant.default.resolution : 1
jira.contact.administrators.message : null
jira.dashboard.max.gadgets : 20
jira.databasequery.batch.size : 100
jira.date.picker.java.format : d/MMM/yy
jira.date.picker.javascript.format : %e/%b/%y
jira.date.time.picker.java.format : dd/MMM/yy h:mm a
jira.date.time.picker.javascript.format : %e/%b/%y %I:%M %p
jira.date.time.picker.use.iso8061 : true
jira.db.txns.disabled : false
jira.default.jndi.name : java:comp/env/jdbc/JiraDS
jira.disable.login.gadget : false
jira.disable.multipart.get.http.request : true
jira.downgrade.minimum.version : 6.1.7
jira.edition : enterprise
jira.email.fromheader.format : ${fullname} (JIRA)
jira.enabled.dark.features :
jira.export.fetchsize : -1
jira.exportimport.cleanxml : true
jira.home :
jira.i18n.include.meta-data : true
jira.i18n.language.index : english
jira.import.maxqueuesize : 100
jira.import.threads : 10
jira.index.background.batch.size : 1000
jira.index.batch.maxbuffereddocs : 300
jira.index.batch.maxmergedocs : 2147483647
jira.index.batch.mergefactor : 50
jira.index.interactive.maxbuffereddocs : 300
jira.index.interactive.maxmergedocs : 2147483647
jira.index.interactive.mergefactor : 4
jira.index.issue.maxqueuesize : 1000
jira.index.issue.minbatchsize : 50
jira.index.issue.threads : 10
jira.index.lock.waittime : 30000
jira.index.max.reindexes : 2147483647
jira.index.maxfieldlength : 10000
jira.index.mergepolicy.expungedeletespctallowed : 10
jira.index.mergepolicy.floorsegmentmb : 2
jira.index.mergepolicy.maxmergeatonce : 10
jira.index.mergepolicy.maxmergeatonceexplicit : 30
jira.index.mergepolicy.maxmergedsegmentmb : 512
jira.index.mergepolicy.nocfspct : 10
jira.index.mergepolicy.segmentspertier : 10
jira.index.mergepolicy.usecompoundfile : true
jira.index.sharedentity.maxqueuesize : 1000
jira.index.sharedentity.minbatchsize : 50
jira.index.sharedentity.threads : 10
jira.index.update.bulk.optimization : 400
jira.issue.actions.order : asc
jira.issue.desc.environment : For example operating system, software platform and/or hardware specifications (include as appropriate for the issue).
jira.issue.desc.original.timetrack : This value can not be changed after work has begun on the issue.
jira.issue.desc.timetrack : An estimate of how much work remains until this issue will be resolved.<br>
The format of this is ' *w *d *h *m ' (representing weeks, days, hours and minutes - where * can be any number)<br>
Examples: 4d, 5h 30m, 60m and 3w.
jira.issueindex.fetch.size : 200
jira.issuenav.criteria.autoupdate : true
jira.jql.autocomplete.disabled : false
jira.lf.application.id : jira
jira.lf.date.complete : dd/MMM/yy h:mm a
jira.lf.date.day : EEEE h:mm a
jira.lf.date.dmy : dd/MMM/yy
jira.lf.date.relativize : true
jira.lf.date.time : h:mm a
jira.lf.favicon.hires.url : /images/64jira.png
jira.lf.favicon.url : /favicon.ico
jira.lf.gadget.color1 : #3b73af
jira.lf.gadget.color2 : #d04437
jira.lf.gadget.color3 : #ea632b
jira.lf.gadget.color4 : #14892c
jira.lf.gadget.color5 : #205081
jira.lf.gadget.color6 : #654982
jira.lf.gadget.color7 : #707070
jira.lf.hero.button.base.bg.colour : #3b7fc4
jira.lf.hero.button.text.colour : #ffffff
jira.lf.logo.height : 30
jira.lf.logo.show.application.title : false
jira.lf.logo.url : /images/icon-jira-logo.png
jira.lf.logo.width : 57
jira.lf.menu.bgcolour : #3b73af
jira.lf.menu.separator : #f0f0f0
jira.lf.menu.textcolour : #ffffff
jira.lf.text.activelinkcolour : #3b73af
jira.lf.text.headingcolour : #292929
jira.lf.text.linkcolour : #3b73af
jira.lf.top.bgcolour : #205081
jira.lf.top.hilightcolour : #296CA3
jira.lf.top.separator.bgcolor : #2E3D54
jira.lf.top.textcolour : #ffffff
jira.lf.top.texthilightcolour : #f0f0f0
jira.mail.fetch.disabled : false
jira.mail.send.disabled : false
jira.max.AdminPage.history.items : 5
jira.max.Issue.history.items : 50
jira.max.JQLQuery.history.items : 10
jira.max.history.items : 10
jira.max.issue.filter.dropdown.items : 10
jira.max.issue.history.dropdown.items : 6
jira.maximum.authentication.attempts.allowed : 3
jira.mode : private
jira.option.allowattachments : true
jira.option.allowcookies : true
jira.option.allowsubtasks : true
jira.option.allowthumbnails : true
jira.option.allowunassigned : false
jira.option.captcha.on.signup : false
jira.option.emailvisible : show
jira.option.ignore.url.with.key : true
jira.option.indexing : true
jira.option.issuelinking : true
jira.option.logoutconfirm : never
jira.option.precedence.header.exclude : false
jira.option.rpc.allow : true
jira.option.timetracking : true
jira.option.user.crowd.allow.rename : true
jira.option.user.externalmanagement : false
jira.option.voting : true
jira.option.watching : true
jira.option.web.usegzip : true
jira.path.attachments : C:\Program Files\Atlassian\Application Data\JIRA\data\attachments
jira.path.attachments.use.default.directory : true
jira.path.backup : C:\Program Files\Atlassian\Application Data\JIRA\export
jira.path.index.use.default.directory : true
jira.project.description.html.enabled : true
jira.project.summary.max.issues : 3
jira.projectkey.description : admin.projects.key.description
jira.projectkey.maxlength : 10
jira.projectkey.pattern : ([A-Z][A-Z]+)
jira.projectkey.reservedwords.list : PRN, AUX, CLOCK$, NUL, COM1, COM2, COM3, COM4, COM5, COM6, COM7, COM8, COM9, CON, LPT1, LPT2, LPT3, LPT4, LPT5, LPT6, LPT7, LPT8, LPT9
jira.projectkey.warning : admin.errors.must.specify.unique.project.key
jira.projectname.maxlength : 80
jira.releasenotes.default : Html
jira.releasenotes.templatenames : Html, Text
jira.releasenotes.templates : releasenotes-html.vm, releasenotes-text.vm
jira.scheme.default.issue.type : 10000
jira.schemes.comparison.max : 5
jira.screenshotapplet.enabled : true
jira.screenshotapplet.linux.enabled : false
jira.search.cache.max.size : 20
jira.search.fullcontentview.pagebreaks : true
jira.search.maxclauses : 65000
jira.search.stable.max.results : 1000
jira.search.views.default.max : 1000
jira.search.views.max.limit : 1000
jira.search.views.max.unlimited.group :
jira.sendmail.recipient.batch.size : 100
jira.setup : true
jira.show.contact.administrators.form : false
jira.subscription.email.max.issues : 200
jira.table.cols.dashboard : issuetype, issuekey, summary, priority
jira.table.cols.subtasks : issuetype, status, assignee, progress
jira.table.cols.voted : issuetype, issuekey, summary, priority, status
jira.table.cols.watched : issuetype, issuekey, summary, priority, status
jira.table.gadget.max.rows : 50
jira.text.field.character.limit : 0
jira.thumbnail.maxheight : 200
jira.thumbnail.maxwidth : 200
jira.timetracking.copy.comment.to.work.desc.on.transition : true
jira.timetracking.days.per.week : 5
jira.timetracking.default.unit : MINUTE
jira.timetracking.estimates.legacy.behaviour : false
jira.timetracking.format : pretty
jira.timetracking.hours.per.day : 8
jira.title : TrialHelp
jira.trustedapp.key.private.data : null
jira.trustedapp.key.public.data : null
jira.trustedapp.uid : jira:13542152
jira.trustedapps.timeout.default : 10000
jira.trustedapps.urlmatch.default : /sr/jira.issueviews:searchrequest
/secure/RunPortlet
/rest
/rpc/soap
/plugins/servlet/streams
/plugins/servlet/applinks
jira.user.avatar.gravatar.enabled : false
jira.usermanagement.maxdisplaymembers : 200
jira.version : 6.2.3
jira.version.patched : 6260
jira.view.issue.links.sort.order : type, status, priority
jira.view.issue.show.quicksubtask.when.no.subtasks : false
jira.viewcvs.root.type : cvsroot
jira.webresource.flushcounter : 6
jira.webresource.superbatch.flushcounter : 63
jira.websudo.is.disabled : false
jira.websudo.timeout : 10
jira.whitelist.disabled : false
jira.whitelist.rules : null
jira.xsrf.enabled : true
ops.bar.group.size.opsbar-admin : 0
ops.bar.group.size.opsbar-transitions : 2
plugins.lastVersion.plugins : 0.8.1068
plugins.lastVersion.server : 6097
show.plugin.marketing.hints : true
user.default.share.private : true
user.issues.per.page : 50
user.keyboard.shortcuts.disabled : false
user.notifications.mimetype : html
user.notify.own.changes : false
user.show.actions.in.navigator : true
webwork.i18n.encoding : UTF-8
webwork.multipart.maxSize : 100485760
___ License Details _______________________
License Set : true
Entitled To Support : true
Evaluation : false
Description : JIRA (Server) 10 Users: Starter License
SEN : SEN-2716147
Organisation : TrialHelp
Partner :
Maximum Number Of Users : 10
___ Database Statistics ___________________
Issues : 4542
Projects : 21
Custom Fields : 19
Workflows : 7
Users : 10
Groups : 8
Attachments : 13974
Comments : 0
___ Upgrade History _______________________
6.2.3#6260
Time Performed : 2014-04-26 16:11:40.597
Original Version : 6.0.2#6097
6.0.2#6097
Time Performed : 2013-06-18 00:23:25.54
___ File Paths ____________________________
JIRA Home : C:\Program Files\Atlassian\Application Data\JIRA
JIRA Local Home : C:\Program Files\Atlassian\Application Data\JIRA
Location of atlassian-jira.log : C:\Program Files\Atlassian\Application Data\JIRA\log\atlassian-jira.log
Index Path : C:\Program Files\Atlassian\Application Data\JIRA\caches\indexes
Attachment Path : C:\Program Files\Atlassian\Application Data\JIRA\data\attachments
___ User Plugins ____________________________
Number : 21
Analytics Client Plugin : com.atlassian.analytics.analytics-client
Version : 3.15
Status : enabled
Vendor : Atlassian
Description :
Atlassian Chaperone : com.atlassian.plugins.atlassian-chaperone
Version : 1.0.20
Status : enabled
Vendor : Atlassian
Description : Provides feature discovery on a per-user basis
Atlassian Hipchat Integration Plugin : com.atlassian.plugins.base-hipchat-integration-plugin
Version : 6.14.0
Status : enabled
Vendor : Atlassian
Description : Provides resources and functionality for linking Atlassian products with hipchat.
Atlassian Hipchat Integration Plugin Core : com.atlassian.plugins.base-hipchat-integration-plugin-api
Version : 6.14.0
Status : enabled
Vendor : Atlassian
Description : This plugin provides an API allowing products to integrate with HipChat.
Atlassian REST API Browser : com.atlassian.labs.rest-api-browser
Version : 3.0.12
Status : enabled
Vendor : Atlassian
Description : Discover, browse, and try Atlassian's rich set or REST and JSON-RPC APIs
Atlassian Universal Plugin Manager - Plugin License Storage plugin : com.atlassian.upm.plugin-license-storage-plugin
Version : 2.7.4
Status : enabled
Vendor : Atlassian
Description : Provides plugin license storage and decoding capabilities in the absence of a licensing-aware UPM. Disabling or uninstalling this plugin may cause purchased plugins to stop working properly.
Atlassian Universal Plugin Manager Plugin : com.atlassian.upm.atlassian-universal-plugin-manager-plugin
Version : 2.18.2
Status : enabled
Vendor : Atlassian
Description : This is the plugin that provides the Atlassian Universal Plugin Manager.
Bob Swift Atlassian Add-ons - JIRA CLI Connector : org.swift.jira.cli
Version : 4.1.0
Status : enabled
Vendor : Bob Swift Atlassian Add-ons (an Appfire Company)
Description : REST API Services for the JIRA Command Line Interface (CLI). A license is not needed if the "Run CLI Actions in JIRA" add-on is enabled and has a valid license.
Database Custom Field : com.keplerrominfo.jira.plugins.databasecf
Version : 3.0.4
Status : enabled
Vendor : Kepler Rominfo
Description : Plugin for custom field that receives information from a database.
Email This Issue Plugin : com.metainf.jira.plugin.emailissue
Version : 6.1.1
Status : enabled
Vendor : META-INF KFT
Description : This plugin allows users to send Issues in email to any arbitrary recipients, manually or automatically via workflow transitions or upon issue events.
HipChat Core Plugin : com.atlassian.hipchat.plugins.core
Version : 0.10.1
Status : enabled
Vendor : Atlassian
Description : A cross product plugin that makes a set of useful HipChat features available for other plugins to use. Compatible with JIRA 5.2+ and Confluence 5.0+
HipChat for JIRA : com.atlassian.labs.hipchat.hipchat-for-jira-plugin
Version : 6.14.0
Status : disabled
Vendor : Atlassian
Description : This is the HipChat plugin for JIRA
JIRA Charting Plugin : com.atlassian.jira.ext.charting
Version : 1.23
Status : enabled
Vendor : Atlassian
Description : JIRA Plugin for graphical charts and graphs.
JIRA Client : com.almworks.jira.plugin.jiraclient
Version : 3.6.3
Status : enabled
Vendor : ALM Works
Description : Desktop app for JIRA power users. JIRA Client is able to work offline and offers fast issue navigation and drill-down, advanced issue triage, and more features to speed up the daily routine. (This plugin installs server-side support and licensing for JIRA Client - the users will need to download and install the client application separately.)
JIRA Drag and Drop Attachment Plugin : com.atlassian.jira.plugins.jira-dnd-attachment-plugin
Version : 3.1.13
Status : enabled
Vendor : Atlassian Pty Ltd.
Description : This is the Drag and Drop Attachments plugin for Atlassian JIRA.
JIRA Importers Plugin (JIM) : com.atlassian.jira.plugins.jira-importers-plugin
Version : 6.3.0
Status : enabled
Vendor : Atlassian
Description : A plugin (originally part of JIRA 4.2 and older) which provides capability to import to JIRA issues from 3rd party issue trackers: Bugzilla, FogBugz and Mantis.
JIRA Working Hours Plugin : com.atlassian.jira.plugins.workinghours
Version : 1.4
Status : enabled
Vendor : Atlassian
Description : JIRA Working Hours Plugin
Quick Subtasks for JIRA : com.hascode.plugin.jira-quick-subtasks
Version : 3.2.1
Status : enabled
Vendor : hasCode.com
Description : The plugin allows you to write down a list of subtasks using a special syntax anywhere you want as a text and then paste them in your JIRA instance to create multiple subtasks for an issue.Features: Manage multiple sub-task templates for each project or user in the administration area, create subtasks when a workflow transition is reached Integration into the workflow editor Optional: Prefix subtasks with parent issue's summaryAttributes: estimate: Estimated time for the subtask e.g. estimate:"4d 20m" assignee: The JIRA user the subtask will be assigned to e.g. assignee:"admin" description: Issue's description e.g. description:"Filter request parameters" priority: The priority. If not specified, the parent issue's priority will be applied to the subtask. e.g. priority:"Critical" component: The component e.g. component:"Documentation" labels (since 2.4.0): One or more labels. Separate multiple labels using a comma e.g. labels:"bug,unconfirmed".
Support Tools Plugin : com.atlassian.support.stp
Version : 3.5.26
Status : enabled
Vendor : Atlassian Support
Description : This is the Support Tools Plugin, developed to help Atlassian customers with our products.
Xporter for JIRA : com.xpandit.plugins.jiraxporter
Version : 3.3.1
Status : enabled
Vendor : Xpand IT
Description : A plugin which exports JIRA Issues to PDF and DOCX Files using templates based on Microsoft Word (DOCX).
katl-commons : com.keplerrominfo.jira.plugins.commons
Version : 3.0.3
Status : enabled
Description : Common Base and Administration for Kepler plugins
___ System Plugins __________________________
Number : 129
ASM : org.objectweb.asm-3.3.1.v201105211655
Version : 3.3.1.v201105211655
Status : enabled
Vendor : Eclipse Orbit
Description :
ActiveObjects Plugin - OSGi Bundle : com.atlassian.activeobjects.activeobjects-plugin
Version : 0.23.2
Status : enabled
Vendor : Atlassian
Description : An OSGi bundle that provides a service that allows plugins to persist objects using the ActiveObjects framework
Apache HttpClient OSGi bundle : org.apache.httpcomponents.httpclient-4.2.5
Version : 4.2.5
Status : enabled
Vendor : The Apache Software Foundation
Description : HttpComponents Client (OSGi bundle)
Apache HttpCore OSGi bundle : org.apache.httpcomponents.httpcore-4.2.4
Version : 4.2.4
Status : enabled
Description : HttpComponents Core (OSGi bundle)
Apache ServiceMix :: Bundles :: javax.inject : org.apache.servicemix.bundles.javax-inject-1.0.0.1
Version : 1.0.0.1
Status : enabled
Description : This OSGi bundle wraps javax.inject 1 jar file.
Applinks Product Plugin : com.atlassian.applinks.applinks-plugin
Version : 4.1.1
Status : disabled
Vendor : Atlassian
Description : Plugin that facilitates discovery, connections and authentication with remote applications
Atlassian - Administration - Quick Search - JIRA : com.atlassian.administration.atlassian-admin-quicksearch-jira
Version : 1.5
Status : disabled
Vendor : Atlassian
Description : Administration Quick Search plugin for JIRA
Atlassian Awareness Capability : com.atlassian.plugins.atlassian-awareness-capability
Version : 0.0.5
Status : disabled
Vendor : Atlassian
Description : This is the com.atlassian.plugins:atlassian-awareness-capability plugin for Atlassian Products.
Atlassian Bot Session Killer : com.atlassian.labs.atlassian-bot-killer
Version : 1.7.5
Status : enabled
Vendor : Atlassian
Description : This will remove unwanted http sessions for requests that exhibit Bot like behaviour. That is they make a single request, don't preserve cookies and never call again.
Atlassian Embedded Crowd - Administration Plugin : com.atlassian.crowd.embedded.admin
Version : 1.7.3
Status : enabled
Vendor : Atlassian
Description : Provides the administration of local and remote user directories.
Atlassian Gadgets OAuth Service Provider Plugin : com.atlassian.gadgets.oauth.serviceprovider
Version : 3.3.4
Status : disabled
Vendor : Atlassian
Description : Plugin that makes OAuth Service Providers Gadget aware.
Atlassian HTTP Client, Apache HTTP components impl : com.atlassian.httpclient.atlassian-httpclient-plugin
Version : 0.17.3
Status : enabled
Vendor : Atlassian
Description : Implementation of the HTTP Client API based on Apache HTTP Components
Atlassian HealthCheck Common Module : com.atlassian.healthcheck.atlassian-healthcheck
Version : 2.0.4
Status : enabled
Vendor : Atlassian
Description : Provides the health-check module and rest endpoints for running the health checks.
Atlassian JIRA - Admin Helper Plugin : com.atlassian.jira.plugins.jira-admin-helper-plugin
Version : 1.18.3
Status : enabled
Description : The Admin Helper plugin helps admins determine visibility of custom fields and also provides reasons for why a user does not have certain permissions on an issue or does not receive notifications for that issue.
Atlassian JIRA - Plugins - Admin Navigation Component : com.atlassian.jira.jira-admin-navigation-plugin
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : Supplies Content to the JIRA Administration Navigation
Atlassian JIRA - Plugins - Application Properties : com.atlassian.jira.jira-application-properties-plugin
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : Provides advanced application properties configuration
Atlassian JIRA - Plugins - Closure Template Renderer : com.atlassian.jira.jira-soy-plugin
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : Provides renderer for Closure templates
Atlassian JIRA - Plugins - Common AppLinks Based Issue Link Plugin : com.atlassian.jira.jira-issue-link-applinks-common-plugin
Version : 6.2.3
Status : disabled
Vendor : ${project.organization.name}
Description : Provides the common utilities for AppLinks based issue link plugins
Atlassian JIRA - Plugins - Confluence Link : com.atlassian.jira.jira-issue-link-confluence-plugin
Version : 6.2.3
Status : disabled
Description : Provides creation and rendering of issue links to Confluence pages
Atlassian JIRA - Plugins - Development Integration Plugin : com.atlassian.jira.plugins.jira-development-integration-plugin
Version : 1.0.0054
Status : disabled
Vendor : Atlassian
Description : Provides better integration for Development Projects In JIRA
Atlassian JIRA - Plugins - Gadgets Plugin : com.atlassian.jira.gadgets
Version : 6.2.3
Status : disabled
Vendor : Atlassian
Description : Provides Gadgets and REST endpoints bundled with JIRA
Atlassian JIRA - Plugins - Header Plugin : com.atlassian.jira.jira-header-plugin
Version : 6.2.3
Status : disabled
Vendor : Atlassian
Description : Provides markup/styles/behaviour/plugin points for the header
Atlassian JIRA - Plugins - Healthcheck Plugin : com.atlassian.jira.plugins.jira-healthcheck-plugin
Version : 1.0.9
Status : enabled
Vendor : Atlassian
Description : This plugin provides health checks for JIRA
Atlassian JIRA - Plugins - Invite User : com.atlassian.jira.jira-invite-user-plugin
Version : 1.15
Status : enabled
Vendor : Atlassian
Description : Allows administrators to invite users to sign up for an account
Atlassian JIRA - Plugins - Issue Navigation : com.atlassian.jira.jira-issue-nav-plugin
Version : 6.2.100
Status : enabled
Vendor : Atlassian
Description : Provides issue search and navigation (rev: 4b1727d, date: 2014-03-04T00:14:19+0000)
Atlassian JIRA - Plugins - Issue Web Link : com.atlassian.jira.jira-issue-link-web-plugin
Version : 6.2.3
Status : enabled
Description : Provides creation and rendering of issue links to web pages
Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin : com.atlassian.jira.lookandfeel
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : Provides logo upload capabilities
Atlassian JIRA - Plugins - Mail Plugin : com.atlassian.jira.jira-mail-plugin
Version : 6.2.4
Status : enabled
Vendor : Atlassian
Description : Handles incoming and outgoing mail
Atlassian JIRA - Plugins - My JIRA Home : com.atlassian.jira.jira-my-home-plugin
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : Lets the user pick a landing page.
Atlassian JIRA - Plugins - OAuth Consumer SPI : com.atlassian.jira.oauth.consumer
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : Provides the Consumer SPI implementation required for OAuth in JIRA.
Atlassian JIRA - Plugins - OAuth Service Provider SPI : com.atlassian.jira.oauth.serviceprovider
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : Provides the OAuth Service Provider SPI implementation required for OAuth in JIRA.
Atlassian JIRA - Plugins - Project Config Plugin : com.atlassian.jira.jira-project-config-plugin
Version : 6.2.3
Status : disabled
Vendor : Atlassian
Description : Provides easier project administration with JIRA
Atlassian JIRA - Plugins - Quick Edit Plugin : com.atlassian.jira.jira-quick-edit-plugin
Version : 1.0.87
Status : disabled
Vendor : Atlassian
Description : This is the com.atlassian.jira:jira-quick-edit-plugin plugin for Atlassian JIRA.
Atlassian JIRA - Plugins - REST Plugin : com.atlassian.jira.rest
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : Provides a REST interface for JIRA
Atlassian JIRA - Plugins - Remote JIRA Link : com.atlassian.jira.jira-issue-link-remote-jira-plugin
Version : 6.2.3
Status : disabled
Description : Provides creation and rendering of links to local and remote JIRA issues
Atlassian JIRA - Plugins - SAL Plugin : com.atlassian.sal.jira
Version : 6.2.3
Status : enabled
Vendor : Atlassian Software Systems
Description : JIRA implementation of the Shared Application Access Layer (SAL)
Atlassian JIRA - Plugins - Share Content Component : com.atlassian.jira.jira-share-plugin
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : Allows users to share issue and searches
Atlassian JIRA - Plugins - User Profile Plugin : com.atlassian.jira.jira-user-profile-plugin
Version : 1.1.3
Status : enabled
Vendor : Atlassian
Description : Plugin uses web-panels to encapsulate details and preferences modules from user profile page.
Atlassian JIRA - Plugins - View Issue Panels : com.atlassian.jira.jira-view-issue-plugin
Version : 6.2.3
Status : disabled
Description : Provides WebPanels for the View Issue Page
Atlassian Navigation Links Plugin : com.atlassian.plugins.atlassian-nav-links-plugin
Version : 3.2.18
Status : disabled
Vendor : Atlassian
Description : Capabilities and Navigation API client and server implementation
Atlassian OAuth Admin Plugin : com.atlassian.oauth.admin
Version : 1.9.0-m3
Status : enabled
Vendor : Atlassian
Description : Plugin that provides a single tabbed view for administering OAuth consumers and service provider information.
Atlassian OAuth Consumer Plugin : com.atlassian.oauth.consumer
Version : 1.9.0-m3
Status : enabled
Vendor : Atlassian
Description : Plugin that makes it possible for applications to become Consumers.
Atlassian OAuth Consumer SPI : com.atlassian.oauth.atlassian-oauth-consumer-spi-1.9.0.m3
Version : 1.9.0.m3
Status : enabled
Vendor : Atlassian
Description : Consumer SPIs to allow applications to provide custom implementations of storing token and consumer info
Atlassian OAuth Service Provider Plugin : com.atlassian.oauth.serviceprovider
Version : 1.9.0-m3
Status : enabled
Vendor : Atlassian
Description : Plugin that makes it possible for applications to become Service Providers.
Atlassian OAuth Service Provider SPI : com.atlassian.oauth.atlassian-oauth-service-provider-spi-1.9.0.m3
Version : 1.9.0.m3
Status : enabled
Vendor : Atlassian
Description : Service Provider SPIs to allow applications to provide custom implementations of storing token consumer info
Atlassian Plugins - Web Resources - Implementation Plugin : com.atlassian.plugins.atlassian-plugins-webresource-plugin
Version : 3.0.0-m24
Status : enabled
Vendor : Atlassian
Description : Base POM for Atlassian projects
Atlassian Pretty URLs Plugin : com.atlassian.prettyurls.atlassian-pretty-urls-plugin
Version : 1.8
Status : enabled
Vendor : Atlassian
Description : Pretty URL support in Atlassian products
Atlassian REST - Module Types : com.atlassian.plugins.rest.atlassian-rest-module
Version : 2.8.4
Status : enabled
Vendor : Atlassian
Description : A plugin that contains REST module types
Atlassian Soy Templates - Plugin : com.atlassian.soy.soy-template-plugin
Version : 2.1.1
Status : enabled
Vendor : Atlassian
Atlassian Template Renderer API : com.atlassian.templaterenderer.api
Version : 1.4.4-m1
Status : enabled
Vendor : Atlassian
Description : API and plugins for easily rendering content from different template engines.
Atlassian Template Renderer Velocity 1.6 Plugin : com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin
Version : 1.4.4-m1
Status : enabled
Vendor : Atlassian
Atlassian UI Plugin : com.atlassian.auiplugin
Version : 5.3.5
Status : enabled
Vendor : Atlassian
Description : An Atlassian plugin that contains the core javascript files used in Atlassian products.
Atlassian WebHooks Plugin : com.atlassian.webhooks.atlassian-webhooks-plugin
Version : 0.17.4
Status : enabled
Vendor : Atlassian
Description : Send expectedEvents over HTTP to registered listeners.
Atlassian Whitelist API Plugin : com.atlassian.plugins.atlassian-whitelist-api-plugin
Version : 1.6
Status : disabled
Vendor : Atlassian
Description : The plugin provides an API to access and persist whitelist information.
Atlassian Whitelist UI Plugin : com.atlassian.plugins.atlassian-whitelist-ui-plugin
Version : 1.6
Status : disabled
Vendor : Atlassian
Description : The plugin provides a user interface to view and modify the application's whitelist.
Bitbucket Importer Plugin for JIM : com.atlassian.jira.plugins.jira-importers-bitbucket-plugin
Version : 1.0.7
Status : enabled
Vendor : Atlassian
Description : A plugin for JIM which provides capability to import JIRA issues from Bitbucket. Requires JIM version 6.0.25+
Crowd REST API : crowd-rest-application-management
Version : 1.0
Status : enabled
Description : Crowd REST API - Application Management
Crowd REST API : crowd-rest-plugin
Version : 1.0
Status : enabled
Crowd System Password Encoders : crowd.system.passwordencoders
Version : 1.0
Status : enabled
Description : Crowd Password Encoders shipped with Crowd
Embedded Gadgets Plugin : com.atlassian.gadgets.embedded
Version : 3.3.4
Status : disabled
Vendor : Atlassian
Description : Plugin which allows gadgets to be embedded in pages
English (United Kingdom) Language Pack : com.atlassian.jira.jira-languages.en_UK
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : This plugin contains translations the core keys in JIRA for English (United Kingdom).
English (United States) Language Pack : com.atlassian.jira.jira-languages.en_US
Version : 6.2.3
Status : enabled
Vendor : Atlassian
Description : This plugin contains translations the core keys in JIRA for English (United States).
FishEye Plugin : com.atlassian.jirafisheyeplugin
Version : 6.2.10
Status : disabled
Description : JIRA Fisheye Plugin
Gadget Dashboard Plugin : com.atlassian.gadgets.dashboard
Version : 3.3.4
Status : disabled
Vendor : Atlassian
Description : Plugin which renders a dashboard of gadgets
Gadget Directory Plugin : com.atlassian.gadgets.directory
Version : 3.3.4
Status : disabled
Vendor : Atlassian
Description : Plugin which renders a directory of gadgets
Gadget Spec Publisher Plugin : com.atlassian.gadgets.publisher
Version : 3.3.4
Status : enabled
Vendor : Atlassian
Description : Plugin which provides a way to publish gadget specs found in plugins
ICU4J : com.atlassian.bundles.icu4j-3.8.0.1
Version : 3.8.0.1
Status : enabled
Description : ICU4J as an OSGi bundle
Issue Status Plugin : com.atlassian.plugins.issue-status-plugin
Version : 1.1.6
Status : enabled
Vendor : Atlassian
Description : This plugin is used to provide assets that can be used in any Atlassian product to render JIRA issue status.
JDOM DOM Processor : com.springsource.org.jdom-1.0.0
Version : 1.0.0
Status : enabled
Vendor : SpringSource
Description :
JIRA Active Objects SPI implementation : com.atlassian.activeobjects.jira.spi
Version : 0.23.2
Status : enabled
Description : A plugin that provides the DataSourceProvider service
JIRA Activity Stream Plugin : com.atlassian.streams.streams-jira-plugin
Version : 5.3.18.1
Status : disabled
Vendor : Atlassian
Description : Lists recent activity in a single project, or in all projects.
JIRA Agile Marketing Plugin : com.atlassian.jira.plugins.greenhopper-marketing-plugin
Version : 1.0.14
Status : enabled
Vendor : Atlassian
Description : Contributes project templates to JIRA that will trigger the installation of JIRA Agile
JIRA Auditing Plugin : com.atlassian.jira.plugins.jira-auditing-plugin
Version : 1.0.4
Status : enabled
Vendor : Atlassian
Description : JIRA Auditing Plugin
JIRA Bamboo Plugin : com.atlassian.jira.plugin.ext.bamboo
Version : 7.1.9
Status : disabled
Vendor : Atlassian Software Systems Pty Ltd
Description : Allows you to see builds and telemetry from a remote Bamboo server
JIRA Base URL Plugin : com.atlassian.jira.jira-baseurl-plugin
Version : 1.9
Status : enabled
Vendor : Atlassian
Description : Detects incorrectly-set base URLs in JIRA.
JIRA Core Project Templates Plugin : com.atlassian.jira-core-project-templates
Version : 2.38
Status : enabled
Vendor : Atlassian
Description : This is the JIRA Core Project Templates Plugin for Atlassian JIRA. (rev: cf7c079, date: 2014-03-07T21:08:17+0000)
JIRA DVCS Connector Plugin : com.atlassian.jira.plugins.jira-bitbucket-connector-plugin
Version : 2.0.3
Status : disabled
Vendor : Atlassian
Description : JIRA DVCS Connector for JIRA, linking JIRA issues to Bitbucket and GitHub changesets.
JIRA Feedback Plugin : com.atlassian.jira.jira-feedback-plugin
Version : 1.12
Status : enabled
Vendor : Atlassian
Description : This is the feedback plugin for Atlassian JIRA.
JIRA French (France) Language Pack : tac.jira.languages.fr_FR
Version : 6.2.1-v2r4732-2014-03-21
Status : enabled
Vendor : Atlassian Community
Description : This plugin contains translations for fr_FR
JIRA German (Germany) Language Pack : tac.jira.languages.de_DE
Version : 6.2.1-v2r8035-2014-03-22
Status : enabled
Description : This plugin contains translations for de_DE
JIRA GitHub Issue Importer : com.atlassian.jira.plugins.jira-importers-github-plugin
Version : 2.0.1
Status : enabled
Vendor : Atlassian
Description : Easy import of issues managed in GitHub repositories into JIRA projects.
JIRA Global Permissions : jira.system.global.permissions
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : This plugin defines all of the default global permissions in JIRA.
JIRA Issue Collector Plugin : com.atlassian.jira.collector.plugin.jira-issue-collector-plugin
Version : 1.4.7
Status : disabled
Vendor : Atlassian
Description : This plugin provides the ability to create issues from remote applications
JIRA JSON-RPC Plugin : com.atlassian.jira.rpc.jira-json-rpc-plugin
Version : 1.0.4
Status : enabled
Description : Exposes JIRA SOAP services using JSON-RPC
JIRA Japanese (Japan) Language Pack : tac.jira.languages.ja_JP
Version : 6.2.1-v2r19395-2014-03-17
Status : enabled
Description : This plugin contains translations for ja_JP
JIRA Mobile : com.atlassian.jira.mobile
Version : 1.6
Status : enabled
Vendor : Atlassian
Description : This is the mobile interface for Atlassian JIRA.
JIRA Monitoring Plugin : com.atlassian.jira.jira-monitoring-plugin
Version : 05.5.4
Status : enabled
Vendor : Atlassian
Description : Records and exposes JIRA key performance metrics
JIRA Password Policy Plugin : com.atlassian.jira.plugins.jira-password-policy-plugin
Version : 1.1.1
Status : enabled
Vendor : Atlassian
Description : Provides a password policy implementation for JIRA
JIRA Projects Plugin : com.atlassian.jira.jira-projects-plugin
Version : 1.0.31
Status : enabled
Vendor : Atlassian
Description : A better project centric JIRA!
JIRA Remote Link Aggregator Plugin : com.atlassian.plugins.jira-remote-link-aggregator-plugin
Version : 2.0.9
Status : disabled
Vendor : Atlassian
Description : Aggregates counts of JIRA outbound links to a given external entity. (rev: 13809b9, date: 2014-01-16T11:02:03+1100)
JIRA Spanish (Spain) Language Pack : tac.jira.languages.es_ES
Version : 6.2.1-v2r17502-2014-03-17
Status : enabled
Description : This plugin contains translations for es_ES
JIRA Streams Inline Actions Plugin : com.atlassian.streams.jira.inlineactions
Version : 5.3.18.1
Status : enabled
Description : JIRA Streams Inline Actions Plugin
JIRA Time Zone Detection plugin : com.atlassian.jira.jira-tzdetect-plugin
Version : 1.8
Status : enabled
Vendor : Atlassian
Description : Performs client-side time zone detection for JIRA.
JIRA Usage Hints : jira.usage.hints
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : This library includes the web fragments for JIRA usage hints displayed on issue operation dialogs. It should never be disabled.
JIRA WebHooks Plugin : com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin
Version : 1.2.5
Status : disabled
Vendor : Atlassian
Description : This plugin provides the ability to register Web Hooks for events in JIRA
JIRA Welcome Plugin : com.atlassian.jira.welcome.jira-welcome-plugin
Version : 1.1.49
Status : enabled
Vendor : Atlassian
Description : Displays a welcome dialog for first-time usage of JIRA, as well as a whats new dialog for users just having upgraded to this version of JIRA.
JIRA Workflow Designer Plugin : com.atlassian.jira.plugins.jira-workflow-designer
Version : 6.2.0.2
Status : enabled
Vendor : Atlassian
Description : The visual way to edit JIRA Workflows.
JIRA Workflow Sharing Plugin : com.atlassian.jira.plugins.workflow.sharing.jira-workflow-sharing-plugin
Version : 1.1.20
Status : enabled
Vendor : Atlassian
Description : Enables exporting and importing of JIRA workflows across instances
JIRA iCalendar Plugin : com.atlassian.jira.extra.jira-ical-feed
Version : 1.0.16
Status : enabled
Vendor : Atlassian
Description : Provides an iCal feed of JIRA issues and versions
JQL Functions : jira.jql.function
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : This plugin implements a JQL function in JIRA.
JSON Library : com.atlassian.bundles.json-20070829.0.0.1
Version : 20070829.0.0.1
Status : enabled
Description : Library for manipulating JSON
Keyboard Shortcuts Plugin : jira.keyboard.shortcuts
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : A plugin that defines a number of keyboard shortcuts.
Neko HTML : com.atlassian.bundles.nekohtml-1.9.12.1
Version : 1.9.12.1
Status : enabled
Description : Neko HTML library as an OSGi bundle
Opensocial Plugin : com.atlassian.gadgets.opensocial
Version : 3.3.4
Status : disabled
Vendor : Atlassian
Description : Plugin for OpenSocial API Support and Gadget Rendering
Project Creation Capability Product REST Plugin : com.atlassian.plugins.atlassian-project-creation-plugin
Version : 1.2.5
Status : disabled
Vendor : Atlassian
Description : This is the com.atlassian.plugins:atlassian-project-creation-plugin plugin for Atlassian Products.
Project Creation Plugin SPI for JIRA : com.atlassian.plugins.jira-project-creation
Version : 1.2.5
Status : enabled
Vendor : Atlassian
Description : This is the com.atlassian.plugins:jira-project-creation plugin for Atlassian JIRA.
Project Templates Plugin : com.atlassian.jira.project-templates-plugin
Version : 2.38
Status : disabled
Vendor : Atlassian
Description : This is the Project Templates Plugin for Atlassian JIRA. (rev: cf7c079, date: 2014-03-07T21:08:17+0000)
ROME, RSS and atOM utilitiEs for Java : rome.rome-1.0
Version : 1.0
Status : enabled
Vendor : Sun Microsystems
Description : All Roads Lead to ROME. ROME is a set of Atom/RSS Java utilities that make it easy to work in Java with most syndication formats. Today it accepts all flavors of RSS (0.90, 0.91, 0.92, 0.93, 0.94, 1.0 and 2.0), Atom 0.3 and Atom 1.0 feeds. Rome includes a set of parsers and generators for the various flavors of feeds, as well as converters to convert from one format to another. The parsers can give you back Java objects that are either specific for the format you want to work with, or a generic normalized SyndFeed object that lets you work on with the data without bothering about the underlying format.
ROME: RSS/Atom syndication and publishing tools : com.springsource.com.sun.syndication-0.9.0
Version : 0.9.0
Status : enabled
Description :
RPC JIRA Plugin : com.atlassian.jira.ext.rpc
Version : 6.0.2
Status : enabled
Vendor : Atlassian
Description : The standard JIRA RPC services, both SOAP and XML-RPC.
Redmine Importers Plugin for JIM : com.atlassian.jira.plugins.jira-importers-redmine-plugin
Version : 2.0.6
Status : enabled
Vendor : Atlassian
Description : A plugin for JIM which provides capability to import JIRA issues from Redmine. Requires JIM version 6.0.25+
Remote Link Aggregator Plugin : com.atlassian.plugins.remote-link-aggregator-plugin
Version : 2.0.9
Status : enabled
Vendor : Atlassian
Description : Aggregates counts of outbound links to a given external entity. (rev: 13809b9, date: 2014-01-16T11:02:03+1100)
Sisu-Inject : org.eclipse.sisu.inject-0.0.0.atlassian6
Version : 0.0.0.atlassian6
Status : enabled
Vendor : The Eclipse Foundation
Description :
Streams API : com.atlassian.streams.streams-api-5.3.18.1
Version : 5.3.18.1
Status : enabled
Vendor : Atlassian
Streams Core Plugin : com.atlassian.streams.core
Version : 5.3.18.1
Status : enabled
Description : Streams Core Plugin
Streams Inline Actions Plugin : com.atlassian.streams.actions
Version : 5.3.18.1
Status : disabled
Description : Streams Inline Actions Plugin
Streams Plugin : com.atlassian.streams
Version : 5.3.18.1
Status : disabled
Description : Streams Plugin
Streams SPI : com.atlassian.streams.streams-spi-5.3.18.1
Version : 5.3.18.1
Status : enabled
Vendor : Atlassian
Streams Third Party Provider Plugin : com.atlassian.streams.streams-thirdparty-plugin
Version : 5.3.18.1
Status : disabled
Vendor : Atlassian
User Format : jira.user.format
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : This plugin renders a user in JIRA.
User Profile Panels : jira.user.profile.panels
Version : 1.0
Status : enabled
Vendor : Atlassian
Description : This library includes the panels included on the user profile page.
Workbox - Common Plugin : com.atlassian.mywork.mywork-common-plugin
Version : 1.8
Status : disabled
Vendor : Atlassian
Description : Provides Common Services to Workbox
Workbox - JIRA Provider Plugin : com.atlassian.mywork.mywork-jira-provider-plugin
Version : 1.8
Status : disabled
Vendor : Atlassian
Description : Generates notifications and tasks from JIRA
atlassian-failure-cache-plugin : com.atlassian.atlassian-failure-cache-plugin
Version : 0.11
Status : enabled
Vendor : Atlassian
Description : This is the Atlassian failure cache plugin, which provides implementations of some core components
jira-help-tips : com.atlassian.plugins.helptips.jira-help-tips
Version : 0.44
Status : enabled
Vendor : Atlassian
Description : Common way to display help tips in the UI of JIRA.
jira-issue-nav-components : com.atlassian.jira.jira-issue-nav-components
Version : 6.2.100
Status : enabled
Vendor : Atlassian
Description : Provides issue search and navigation components
jquery : com.atlassian.plugins.jquery
Version : 1.7.2
Status : enabled
Vendor : (unknown)
Description : Atlassian plugin wrapper containing only jQuery.
scala-provider-plugin : com.atlassian.scala.plugins.scala-2.10-provider-plugin
Version : 0.4
Status : enabled
Vendor : Atlassian
Description : This plugin provides the scala runtime for scala 2.10.1
sisu-guice : org.sonatype.sisu.guice-3.1.3
Version : 3.1.3
Status : enabled
Vendor : Sonatype, Inc.
Description : Patched build of Guice: a lightweight dependency injection framework for Java 5 and above
___ Listeners _____________________________
Instance Count : 3
Mail Listener : com.atlassian.jira.event.listeners.mail.MailListener
Issue Assignment Listener : com.atlassian.jira.event.listeners.history.IssueAssignHistoryListener
Issue Index Listener : com.atlassian.jira.event.listeners.search.IssueIndexListener
___ Services ______________________________
Instance Count : 13
Backup Service : com.atlassian.jira.service.services.export.ExportService
Service Delay : 43200000ms
USE_DEFAULT_DIRECTORY : true
LocalPluginLicenseNotificationJob-job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
Service Delay : 86400000ms
Mail Queue Service : com.atlassian.jira.service.services.mail.MailQueueService
Service Delay : 60000ms
PluginRequestCheckJob-job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
Service Delay : 3600000ms
PluginUpdateCheckJob-job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
RemotePluginLicenseNotificationJob-job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
Service Provider Session Remover : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
Service Delay : 28800000ms
com.atlassian.analytics.client.upload.S3EventUploader:job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
Service Delay : 87262891ms
com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
com.atlassian.jira.plugins.workflow.sharing.file.FileCleaningJob : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
Service Delay : 300000ms
com.javahollic.jira.emh.service.scheduling.JEMHJobSchedulerImpl:job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService
Service Delay : 1000ms
jiracom : com.atlassian.jira.service.services.mail.MailFetcherService
popserver : jiracom
handler.params : project=COM,issuetype=3,reporteruserkey=vladimir.buzalka,bulk=ignore,createusers=false,notifyusers=true,ccwatcher=false,ccassignee=true,stripquotes=false
handler : admin.service.common.handler.create.or.comment
___ Trusted Applications __________________
Instance Count : 1
Application Name : confluence:16677674
Matching URLs :
Matching IP :
___ Java Class Paths ______________________
sun.boot.class.path : c:\Program Files\Atlassian\JIRA\jre\lib\resources.jar;
c:\Program Files\Atlassian\JIRA\jre\lib\rt.jar;
c:\Program Files\Atlassian\JIRA\jre\lib\sunrsasign.jar;
c:\Program Files\Atlassian\JIRA\jre\lib\jsse.jar;
c:\Program Files\Atlassian\JIRA\jre\lib\jce.jar;
c:\Program Files\Atlassian\JIRA\jre\lib\charsets.jar;
c:\Program Files\Atlassian\JIRA\jre\lib\jfr.jar;
c:\Program Files\Atlassian\JIRA\jre\classes
java.library.path : c:\Program Files\Atlassian\JIRA\jre\bin;
C:\WINDOWS\Sun\Java\bin;
C:\WINDOWS\system32;
C:\WINDOWS;
C:\WINDOWS;
C:\WINDOWS\System32\Wbem;
java.endorsed.dirs : c:\Program Files\Atlassian\JIRA\endorsed
java.ext.dirs : c:\Program Files\Atlassian\JIRA\jre\lib\ext;
C:\WINDOWS\Sun\Java\lib\ext
java.class.path : c:\Program Files\Atlassian\JIRA\bin\bootstrap.jar;
c:\Program Files\Atlassian\JIRA\bin\tomcat-juli.jar
2016-05-09 21:35:14,691 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
JIRA 6.2.3 build: 6260 started. You can now access JIRA through your web browser.
2016-05-09 21:35:14,722 localhost-startStop-1 FATAL [atlassian.jira.startup.JiraStartupLogger]
The following plugins are required by JIRA, but have not been started: Atlassian JIRA - Plugins - Project Config Plugin (com.atlassian.jira.jira-project-config-plugin), Embedded Gadgets Plugin (com.atlassian.gadgets.embedded), Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard), Opensocial Plugin (com.atlassian.gadgets.opensocial), Gadget Directory Plugin (com.atlassian.gadgets.directory), Atlassian Navigation Links Plugin (com.atlassian.plugins.atlassian-nav-links-plugin), Applinks Product Plugin (com.atlassian.applinks.applinks-plugin), Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets), Atlassian JIRA - Plugins - Quick Edit Plugin (com.atlassian.jira.jira-quick-edit-plugin)
2016-05-09 21:35:14,722 localhost-startStop-1 FATAL [atlassian.jira.upgrade.UpgradeLauncher] Skipping, JIRA is locked.
2016-05-09 21:35:14,722 localhost-startStop-1 INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler not started: JIRA startup checklist failed.
2016-05-09 21:35:14,738 localhost-startStop-1 WARN [atlassian.jira.startup.JiraStartupLogger]
___ FAILED PLUGIN REPORT _____________________
35 plugins failed to load during JIRA startup.
'com.atlassian.applinks.applinks-plugin' - 'Applinks Product Plugin' failed to load.
Application context initialization for 'com.atlassian.applinks.plugin' has timed out
It has the following missing service dependencies :
&requestFactory of type (objectClass=com.atlassian.sal.api.net.RequestFactory)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\applinks-plugin-4.1.1.jar
'com.atlassian.jira.jira-quick-edit-plugin' - 'Atlassian JIRA - Plugins - Quick Edit Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.jira-quick-edit-plugin' has timed out
&beanBuilderFactory of type (objectClass=com.atlassian.jira.rest.v2.issue.builder.BeanBuilderFactory)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-quick-edit-plugin-1.0.87.jar
'com.atlassian.jira.jira-header-plugin' - 'Atlassian JIRA - Plugins - Header Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.header-plugin' has timed out
&applicationLinkService of type (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-header-plugin-6.2.3.jar
'com.atlassian.plugins.jira-remote-link-aggregator-plugin' - 'JIRA Remote Link Aggregator Plugin' failed to load.
Application context initialization for 'com.atlassian.plugins.jira-remote-link-aggregator-plugin' has timed out
&linked-application-capabilities of type (objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)
&application-link-service of type (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-remote-link-aggregator-plugin-2.0.9.jar
'com.atlassian.jira.jira-issue-link-applinks-common-plugin' - 'Atlassian JIRA - Plugins - Common AppLinks Based Issue Link Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.issue-link-applinks-common-plugin' has timed out
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-applinks-common-plugin-6.2.3.jar
'com.atlassian.jira.gadgets' - 'Atlassian JIRA - Plugins - Gadgets Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.gadgets-plugin' has timed out
&outboundWhitelist of type (objectClass=com.atlassian.plugins.whitelist.OutboundWhitelist)
&externalWhitelistService of type (objectClass=com.atlassian.plugins.whitelist.WhitelistService)
&gadgetViewFactory of type (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
&dashboardService of type (objectClass=com.atlassian.gadgets.dashboard.DashboardService)
&gadgetRequestContextFactory of type (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-gadgets-plugin-6.2.3.jar
'com.atlassian.jira.jira-issue-link-remote-jira-plugin' - 'Atlassian JIRA - Plugins - Remote JIRA Link' failed to load.
Application context initialization for 'com.atlassian.jira.issue-link-remote-jira-plugin' has timed out
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-remote-jira-plugin-6.2.3.jar
'com.atlassian.administration.atlassian-admin-quicksearch-jira' - 'Atlassian - Administration - Quick Search - JIRA' failed to load.
Application context initialization for 'com.atlassian.administration.atlassian-admin-quicksearch-jira' has timed out
&sal-request-factory-import of type (objectClass=com.atlassian.sal.api.net.RequestFactory)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-admin-quicksearch-jira-1.5.jar
'com.atlassian.gadgets.embedded' - 'Embedded Gadgets Plugin' failed to load.
The plugin has been disabled. A likely cause is that it timed out during initialisation
&gadgetSpecFactory of type (&(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory))
&securityTokenFactory of type (&(objectClass=com.atlassian.gadgets.view.SecurityTokenFactory)(objectClass=com.atlassian.gadgets.view.SecurityTokenFactory))
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-embedded-plugin-3.3.4.jar
'com.atlassian.plugins.atlassian-awareness-capability' - 'Atlassian Awareness Capability' failed to load.
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-awareness-capability-0.0.5.jar
'com.atlassian.gadgets.opensocial' - 'Opensocial Plugin' failed to load.
&appLinksService of type (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-opensocial-plugin-3.3.4.jar
'com.atlassian.plugins.atlassian-whitelist-ui-plugin' - 'Atlassian Whitelist UI Plugin' failed to load.
Application context initialization for 'com.atlassian.plugins.atlassian-whitelist-ui-plugin' has timed out
&inboundWhitelist of type (objectClass=com.atlassian.plugins.whitelist.InboundWhitelist)
&whitelistService of type (objectClass=com.atlassian.plugins.whitelist.WhitelistService)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-whitelist-ui-plugin-1.6.jar
'com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin' - 'JIRA WebHooks Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin' has timed out
&applicationLinkService of type (objectClass=com.atlassian.applinks.spi.link.MutatingApplicationLinkService)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-webhooks-plugin-1.2.5.jar
'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' - 'JIRA Issue Collector Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.collector.plugin.jira-issue-collector-plugin' has timed out
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-collector-plugin-1.4.7.jar
'com.atlassian.streams.streams-jira-plugin' - 'JIRA Activity Stream Plugin' failed to load.
Application context initialization for 'com.atlassian.streams.jira-plugin' has timed out
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-jira-plugin-5.3.18.1.jar
'com.atlassian.mywork.mywork-common-plugin' - 'Workbox - Common Plugin' failed to load.
Application context initialization for 'com.atlassian.mywork.common-plugin' has timed out
&authenticationConfigurationManager of type (objectClass=com.atlassian.applinks.spi.auth.AuthenticationConfigurationManager)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\mywork-common-plugin-1.8.jar
'com.atlassian.streams.actions' - 'Streams Inline Actions Plugin' failed to load.
Application context initialization for 'com.atlassian.streams.inline-actions-plugin' has timed out
&streamsLocaleProvider of type (objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-inline-actions-plugin-5.3.18.1.jar
'com.atlassian.gadgets.directory' - 'Gadget Directory Plugin' failed to load.
&subscribedGadgetFeedStore of type (&(objectClass=com.atlassian.gadgets.directory.spi.SubscribedGadgetFeedStore)(objectClass=com.atlassian.gadgets.directory.spi.SubscribedGadgetFeedStore))
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-directory-plugin-3.3.4.jar
'com.atlassian.jira.project-templates-plugin' - 'Project Templates Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.plugins.project-templates-plugin' has timed out
&entityLinkService of type (objectClass=com.atlassian.applinks.api.EntityLinkService)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\project-templates-plugin-2.38.jar
'com.atlassian.plugins.atlassian-whitelist-api-plugin' - 'Atlassian Whitelist API Plugin' failed to load.
Application context initialization for 'com.atlassian.plugins.atlassian-whitelist-api-plugin' has timed out
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-whitelist-api-plugin-1.6.jar
'com.atlassian.streams' - 'Streams Plugin' failed to load.
Application context initialization for 'com.atlassian.streams.aggregator-plugin' has timed out
&formatPreferenceProvider of type (objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)
&applinkService of type (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
&entityResolvers of type (objectClass=com.atlassian.streams.spi.EntityResolver)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-aggregator-plugin-5.3.18.1.jar
'com.atlassian.gadgets.oauth.serviceprovider' - 'Atlassian Gadgets OAuth Service Provider Plugin' failed to load.
&gadgetRequestContextFactory of type (&(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory))
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-oauth-service-provider-plugin-3.3.4.jar
'com.atlassian.jira.plugin.ext.bamboo' - 'JIRA Bamboo Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.plugins.jira-bamboo-plugin' has timed out
&typeAccessor of type (objectClass=com.atlassian.applinks.spi.util.TypeAccessor)
&linkedApplicationCapabilities of type (objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\installed-plugins\plugin.1219393315297950440.jira-bamboo-plugin-6.1.10.jar
'com.atlassian.jira.plugins.jira-development-integration-plugin' - 'Atlassian JIRA - Plugins - Development Integration Plugin' failed to load.
&applicationLinkService of type (&(objectClass=com.atlassian.applinks.api.ApplicationLinkService)(objectClass=com.atlassian.applinks.api.ApplicationLinkService))
&remoteNavigationLinkService of type (&(objectClass=com.atlassian.plugins.navlink.consumer.menu.services.RemoteNavigationLinkService)(objectClass=com.atlassian.plugins.navlink.consumer.menu.services.RemoteNavigationLinkService))
&linkedApplicationCapabilities of type (&(objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities)(objectClass=com.atlassian.plugins.capabilities.api.LinkedApplicationCapabilities))
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-development-integration-plugin-1.0.0054.jar
'com.atlassian.jirafisheyeplugin' - 'FishEye Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.plugins.jira-fisheye-plugin' has timed out
&entityLinkService of type (objectClass=com.atlassian.applinks.spi.link.MutatingEntityLinkService)
&manifestRetriever of type (objectClass=com.atlassian.applinks.spi.manifest.ManifestRetriever)
&mutatingApplicationLinkService of type (objectClass=com.atlassian.applinks.spi.link.MutatingApplicationLinkService)
&entityBuilderFactory of type (objectClass=com.atlassian.applinks.spi.link.EntityLinkBuilderFactory)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-fisheye-plugin-6.2.10.jar
'com.atlassian.plugins.atlassian-nav-links-plugin' - 'Atlassian Navigation Links Plugin' failed to load.
Application context initialization for 'com.atlassian.plugins.atlassian-nav-links-plugin' has timed out
&mutatingEntityLinkService of type (objectClass=com.atlassian.applinks.spi.link.MutatingEntityLinkService)
&projectPermissionManager of type (objectClass=com.atlassian.plugins.navlink.spi.ProjectPermissionManager)
&projectManager of type (objectClass=com.atlassian.plugins.navlink.spi.ProjectManager)
&app-link-service of type (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
&weights of type (objectClass=com.atlassian.plugins.navlink.spi.weights.ApplicationWeights)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-nav-links-plugin-3.2.18.jar
'com.atlassian.jira.jira-view-issue-plugin' - 'Atlassian JIRA - Plugins - View Issue Panels' failed to load.
Application context initialization for 'com.atlassian.jira.view-issue-plugin' has timed out
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-view-issue-plugin-6.2.3.jar
'com.atlassian.plugins.atlassian-project-creation-plugin' - 'Project Creation Capability Product REST Plugin' failed to load.
&entity-link-builder-factory of type (objectClass=com.atlassian.applinks.spi.link.EntityLinkBuilderFactory)
&type-accessor of type (objectClass=com.atlassian.applinks.spi.util.TypeAccessor)
&mutating-entity-link-service of type (objectClass=com.atlassian.applinks.spi.link.MutatingEntityLinkService)
&custom-content-links of type (objectClass=com.atlassian.plugins.navlink.producer.contentlinks.customcontentlink.CustomContentLinkService)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-project-creation-plugin-1.2.5.jar
'com.atlassian.jira.jira-project-config-plugin' - 'Atlassian JIRA - Plugins - Project Config Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.project-config-plugin' has timed out
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-project-config-plugin-6.2.3.jar
'com.atlassian.mywork.mywork-jira-provider-plugin' - 'Workbox - JIRA Provider Plugin' failed to load.
Application context initialization for 'com.atlassian.mywork.jira-provider-plugin' has timed out
&notificationService of type (&(objectClass=com.atlassian.mywork.service.NotificationService)(type=delegator))
&hostService of type (objectClass=com.atlassian.mywork.service.HostService)
&taskService of type (&(objectClass=com.atlassian.mywork.service.TaskService)(type=delegator))
&serviceSelector of type (objectClass=com.atlassian.mywork.service.ServiceSelector)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\mywork-jira-provider-plugin-1.8.jar
'com.atlassian.jira.jira-issue-link-confluence-plugin' - 'Atlassian JIRA - Plugins - Confluence Link' failed to load.
Application context initialization for 'com.atlassian.jira.issue-link-confluence-plugin' has timed out
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\jira-issue-link-confluence-plugin-6.2.3.jar
'com.atlassian.labs.hipchat.hipchat-for-jira-plugin' - 'HipChat for JIRA' failed to load.
&projectConfigRequestCache of type (objectClass=com.atlassian.jira.projectconfig.util.ProjectConfigRequestCache)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\installed-plugins\hipchat-for-jira-plugin-6.14.0.jar
'com.atlassian.streams.streams-thirdparty-plugin' - 'Streams Third Party Provider Plugin' failed to load.
Application context initialization for 'com.atlassian.streams.thirdparty-plugin' has timed out
&userProfileAccessor of type (objectClass=com.atlassian.streams.spi.UserProfileAccessor)
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\streams-thirdparty-plugin-5.3.18.1.jar
'com.atlassian.jira.plugins.jira-bitbucket-connector-plugin' - 'JIRA DVCS Connector Plugin' failed to load.
Application context initialization for 'com.atlassian.jira.plugins.jira-bitbucket-connector-plugin' has timed out
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\installed-plugins\plugin.2723688556565403471.jira-dvcs-connector-plugin-1.4.3.jar
'com.atlassian.gadgets.dashboard' - 'Gadget Dashboard Plugin' failed to load.
&gadgetSpecUrlChecker of type (&(objectClass=com.atlassian.gadgets.GadgetSpecUrlChecker)(objectClass=com.atlassian.gadgets.GadgetSpecUrlChecker))
&renderedGadgetUriBuilder of type (&(objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder)(objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder))
It was loaded from C:\Program Files\Atlassian\Application Data\JIRA\plugins\.bundled-plugins\atlassian-gadgets-dashboard-plugin-3.3.4.jar
2016-05-09 21:35:14,988 localhost-startStop-1 ERROR [jira.web.dispatcher.JiraWebworkActionDispatcher]
JIRA startup failed, JIRA has been locked.
2016-05-09 21:35:19,737 Modification Check:thread-1 INFO [atlassian.jira.startup.JiraStartupLogger]
