I am trying to create a page displaying data about the current jira project. It should be accessible through the sidebar (project-centric-view).
The page has been made accessibel through a WebItem (link in the sidebar). The page itself is rendered as a WebPanel. I have provided the Panel with a contextrenderer (extends AbstractJiraContextProvider) which allows me to override the getContextMap(ApplicationUser, JiraHelper) method.
I would need the projectId of the current project to retrieve the data I want to display, however the JiraHelper object returns null on the getProject() call.
So how do I get a hold of the projectId?
I suspect that I would need to pass it as a parameter, possibly form the WebItem, but how would I do this?
Any help would be appreciated.
atlassian-plugin.xml
<web-item key="overview-menu-item" name="Upsource Overview Link"
              section="jira.project.sidebar.plugins.navigation"
              weigth="30" application="jira">
        <desctiption>Link to the upsource connectivity overview page for this project</desctiption>
        <label key="upsource-connectivity.overview.label"/>
        <link linkId="upsource-connectivity-overview-link">/projects/$pathEncodedProjectKey?selectedItem=com.atlassian.jira.jira-projects-plugin:upsource-overview-page</link>
        <param name="iconClass" value="aui-icon-large icon-sidebar-issues"/>
    </web-item>
    <web-panel key="upsource-overview-panel" location="com.atlassian.jira.jira-projects-plugin:upsource-overview-page">
        <description>Project overview of open upsource reviews</description>
        <resource name="view" type="velocity" location="templates/OverviewPanel.vsl"/>
        <context-provider class="com.nikon.developmenttools.impl.OverviewContextProvider"/>
    </web-panel>ContextProvider class
public class OverviewContextProvider extends AbstractJiraContextProvider {
    @Inject
    private UpsourceConnectivityExtentionMethods methodContainer;
    public OverviewContextProvider(){}
    public UpsourceConnectivityExtentionMethods getMethodContainer() {
        return methodContainer;
    public void setMethodContainer(UpsourceConnectivityExtentionMethods methodContainer) {
        this.methodContainer = methodContainer;
    @Override
    public Map getContextMap(ApplicationUser au, JiraHelper jh) {
        Map contextMap = new HashMap();
        List<String> exceptionMessages = new ArrayList<String>();
        try{
            Project currentProject = (Project) (jh.getProject());
            if(currentProject == null){
                String message = "it's the currentproject"
                        + "\nqs: " + jh.getQueryString()
                        + "\ncontextparam: "+ jh.getContextParams().toString();
                throw new Exception(message);
            UpsourceConfig uc = this.methodContainer.loadConfig(currentProject.getKey());
            HashMap<String, String> ucProperties = new HashMap<String, String>();
            ucProperties.put("host", uc.getHost());
            ucProperties.put("user", uc.getUsername());
            ucProperties.put("upsourceId", uc.getUpsourceProjectId());
            contextMap.put("config", ucProperties);
            ResultDTO result = this.methodContainer.getReviews(currentProject);
            if(result == null || result.getResult() == null){
                throw new Exception("its the result");
            ReviewsDTO response = (ReviewsDTO) result.getResult();
            contextMap.put("reviewsDTO", response);
        }catch (UpsourceConnectionFailureException ucfe) {
            System.err.println("UPSOURCE CONNECTION EXCEPTION: " + ucfe.getMessage());
            if (ucfe.getCause() != null && ucfe.getCause().getCause() instanceof java.net.UnknownHostException) {
                exceptionMessages.add("Error resolving host, please check the Upsource Connectivity Settings for this project and your network settings.");
            } else {
                exceptionMessages.add(ucfe.toString());
        } catch (UpsourceUnsetConfigException uuce) {
            System.err.println("UPSOURCE CONFIGRATION EXCEPTION: " + uuce.getMessage());
            exceptionMessages.add(uuce.getMessage());
        } catch (UpsourceConnectivityException uce) {
            System.err.println("UPSOURCE EXCEPTION: " + uce.getMessage());
            if (uce.getCause() != null) {
                exceptionMessages.add(uce.getCause().toString());
            } else {
                exceptionMessages.add(uce.toString());
        } catch (Exception ex) {
            exceptionMessages.add(ex.toString());
            System.err.println("EXCEPTION: " + ex.toString());
        contextMap.put("exceptionList", exceptionMessages);
        return contextMap;
Overview Page
<div class="mod-header">
    <h2>Code Reviews</h2>
    #if( !$exceptionList.isEmpty() )
        <h3>Error</h3>
        #foreach( $exception in $exceptionList )
            <p>$exception.toString()</p>
        #end
    #end
    #if($reviewsDTO.reviews.isEmpty())
        <p>No reviews available.</p>
    #else
    #foreach( $review in $reviewsDTO.reviews )
        <table>
        <tr>
        <td><h4>$review.reviewId.reviewId</h4></td>
        </tr>
        <tr>
        <td>State: #if($review.state == 1)
            Open
            #else
            Closed
            #end
            </td>
        </tr>
        <tr>
        <td><a href="${review.additionalProperties.get("link")}">Go to review ${review.reviewId.reviewId}</a></td>
        </tr>
        </table>
        <br/>
    #end
    #end
</div>
Hi Robrecht,
I have same requirement and even me too facing the same issue in getting the projectId from the sidebar (project-centric-view).
Hope you might have got the solution for this. Could you please provide any link with the solution?
Thanks in advance!
-Kumar
Define in your web-item a link like the below:
<link>/projects/$pathEncodedProjectKey?selectedItem=com.snowlinesoftware.irae:project-treemap-web-panel&projectKey=$pathEncodedProjectKey</link>
See, the projectKey parameter will have value $pathEncodedProjectKey which is the key of your project. Then, in your class extending AbstractJiraContextProvider in the getContextMap method you just get it from the jiraHelper as a GET parameter:
String projectKey = jiraHelper.getRequest().getParameter("projectKey");
Hi Robrecht - since this is development related, you might want to try asking this over at: https://community.developer.atlassian.com as well (if you haven't already).
There's a lot of helpful and experienced people over there. You might well get a quicker answer in there than on here.
