I need an automation rule to be scheduled on a weekly basis to get the conversion rate and update the Jira fields for the conversion rate. i have Jira fields like Euro Conversion rate
GBP Conversion rate
USD Conversion rate
AED Conversion rate
OMR Conversion rate
Now these five currencies should be converted into AED in the backend. It should be done using the Exchange rate API key.
Hi @Seenivasan K -- Welcome to the Atlassian Community!
What have you done thus far to solve this need?
If you have an automation rule that is not working as expected, please post the following so the community can provide suggestions:
If you have not yet started a rule, I suggest trying to do so. This community is a place for people to learn, share ideas, and help one another. It is not a free labor pool to implement requests upon demand. If you regularly need help creating automation rules, I recommend working with your Jira Site Admin to learn more.
To get you started on creating your rule, please refer to these documentation and example sources:
