We are using Jira on demand and the Jira Misc Workflow plugin is enabled. I want to add a post condition to our workflow for Transitioning Parent Issue when subtasks are updated, but I don't see that option when viewing the workflow post conditions options. How do I add this into our workflow? I looked at the documentation at the link below, but it didn't help me figure out how to do what I needed because I need more info where I even start. Here's the link I looked at: https://studio.plugins.atlassian.com/wiki/display/JMWE/JIRA+Misc+Workflow+Extensions+Documentation#JIRAMiscWorkflowExtensionsDocumentation-Installation.
Thanks for the help!
Thank you Justin and John. I have confirmed that the plugin is enabled in the admin tools, and that 21 our of 21 modules are enabled.
John - Are the steps you are describing for Jira OnDemand or if you host your own instance of Jira? I'm unfamiliar with the directories you are mentioning. Our company used Jira OnDemand.
Hi Rebecca,
Kindly ensure the plugin is compatible with your Jira instance. Next, please try the following steps:
Hope it helps.
John
Hi Rebecca,
Can you ensure that the plugin has been enabled via the Manage Plugins page? Once this plugin has been enabled, you can then view the post function in the list of post functions. :)
