Hi, Team
We have a PCFU field in one project, which we want to copy/automate into a different project using Automation rule.
Rule1. When a "feature" in first project is created with "type of work" field as capex, we create the issue in second project with auto populating the PCFU field value of one project into other.
What I have tried so far?
{{issue.customfield_21007.label.asJsonString}} I have used this for the field but still I dont see the field updated in the second project.
Created a PCFU field for the destination project but in the set fields to choose, I dont see the PCFU field?.
Could you please help me on this?
@Arunajyothi Samala can you confirm that the PCFU field is applicable to the Project and Issue Type you're trying to set? If either are specifically excluded you will not be able to set the field as desired.
