I need help writing a script for Jira that when you enter a username and a role it will check for which projects the user is assigned to that role. I am quite new to Jira so thank you for the help in advance.
Also, examples of similar scripts would be quite helpful as well. Thanks.
Hi Nora,
you might also be interested in the Atlassian Developer Community.
Thank you
