The button, to pull up the issue collector, needs to be clicked twice in order for the collector to pop up.
running jQuery version 1.12.4
Current code:
In html file:
<button id="nameOfButton" (click)="nameOfButton">Name of Button</button>
In ts file:
import * as jQuery from 'jquery';
declare global {
   interface Window {
     ALT_JQ_PAGE_PROPS: any;
window.ALT_JQ_PAGE_PROPS = window.ALT_JQ_PAGE_PROPS || {};
@Component({ })nameOfButton() {
    jQuery.ajax({url: 'https://url/plugins/servlet/issueCollectorBootstrap.js?collectorId=numberid&locale=en_US',
       type: 'get',
       cache: true,
       dataType: 'script',
     })triggerFunction: function (showCollectorDialog: any) {
//Requires that jQuery is available!
jQuery('#nameOfButton').on('click', function (e) {
e.preventDefault();
showCollectorDialog();
e.stopImmediatePropagation(); <- this is added by us to stop overlapping->
@Misty Ramsdell Welcome to the Atlassian community
We just used the API and integrated that into our support form. This gave us more control of the information that we collected, and we do not have to rely on the issue collector. The issue collector is an easy to use / implement solution, but you have less control over it since it uses Atlassian code. The API give you full control since you build the frontend.
