I am not able to save the author of a comment while i add a comment to issue using REST AP. Is there any way to do it ? please share the Json body.
url: /rest/api/3/issue/{issueIdOrKey}/comment.
Hi @jay
You will not be able to add the comment as any other user. The author of a comment is the user associated with the auth token.
Hope this helps!
Thank you @Anandhi Arumugam _Cprime_ for your help and support. From some of the documents also I got the same answer. Thank you.
