I'm getting the following error in Jira log when trying to create an issue from my java application:
2018-04-11 16:14:13,999 http-nio-8081-exec-8 WARN anonymous 974x1100x1 - 192.168.0.123 /rest/api/latest/issue [c.a.o.serviceprovider.internal.AuthenticatorImpl] Problem encountered authenticating OAuth client for url "http://example.com:8081/rest/api/latest/issue", error was "signature_invalid", with parameters "{oauth_problem=signature_invalid, oauth_signature=rKWSa6GEzeQOeddx1OeHXEIb7t3b4LBnoHrR1xxUpsD9mlSFx6JefEBGn/s5ZBOtM/w3kK+IEHVeeiBPl0LhaVIkmn2aJ01qkJvnByJ0nd9ryWCYZ3Sn8c6cah4ER0taUCN+HkL2L47NPMTC4jcn5HZGKm/phkljr5o3qNxcx5U=, oauth_signature_base_string=POST&http%3A%2F%2Fexample.com%3A8081%2Frest%2Fapi%2Flatest%2Fissue&oauth_consumer_key%3DOauthKey%26oauth_nonce%3D20243586694535%26oauth_signature_method%3DRSA-SHA1%26oauth_timestamp%3D1523456053%26oauth_token%3DDJgZkfen79tRrMJYKjphabVERQ6hj54Q%26oauth_version%3D1.0, oauth_signature_method=RSA-SHA1}
I could get read operations working well so my access token, public/private key and consumer key are well configured in both sides, however when trying "write operations" I'm getting always oauth_problem=signature_invalid.
I also removed proxy and ssl from jira instance to make sure this was not causing the problem, as per https://confluence.atlassian.com/applinks/oauth-troubleshooting-guide-790632058.html#OAuthtroubleshootingguide-OAuthinvalidsig
Regarding the other possibility pointed "The application URL for the link does not match the URL that the remote application is reporting.", my url is accesible from Jira server as I could reach it doing a curl (both Jira server and my app are in the same internal network).
Could you please help on this?
This also can be caused by
<jira-install>/conf/server.xml is set to trueIf yes, you can change it to false.
