CC Lastcomment add on: Failed to load a valid ServiceRocket Jira Utility Plugin License
iComm Corporation October 20, 2020
hi Dears,
we have pay the license for CC lastcomments add on, but now the add on display "Failed to load a valid ServiceRocket Jira Utility Plugin License", what is the problem? how can I fix it? image.pngimage.png
Azwandi [ServiceRocket]
Hi there, I believe you have two apps in place. You paid for the CCC Last Comment app but the custom field you're using is not from that app. I would recommend you to contact the app vendor to get further assistance (https://marketplace.atlassian.com/apps/15064/ccc-last-comment?hosting=server&tab=support)
Please help
