Post function Script to add a watcher for specific issue
Pritesh Jagani October 17, 2017
Hi ,
I am getting following error
Time (on server): Mon Oct 16 2017 17:37:53 GMT-0700 (Pacific Daylight Time)
The following log information was produced by this execution. Use statements like:log.info("...") to record logging information.
2017-10-16 17:37:53,779 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2017-10-16 17:37:53,779 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: CR-2024, actionId: 1, file: <inline script>
groovy.lang.MissingPropertyException: No such property: event for class: Script54
 at Script54.run(Script54.groovy:8)
Here's my script
import com.atlassian.jira.user.util.UserManager
import com.atlassian.jira.issue.watchers.WatcherManager
def watcherManager = ComponentAccessor.getWatcherManager()
def userManager = ComponentAccessor.getUserManager()
def issue = event.getIssue()
def user = userManager.getUserByName("Brian66481")
if (issue.getIssueType().getName() == "RE Task") watcherManager.startWatching(user, issue)
Please help
Pritesh Jagani October 18, 2017
Here's the solution
MoroSystems Support
October 17, 2017
Hello Pritesh,
the problem seems to be at the line "def issue = event.getIssue()". The event variable is not available for your script.
I think if you will delete the whole line, the issue will disappear (as the issue variable is automatically available in post function scripts).
Please let me now if it helped.
Martin
Hi Martin,
Unfortunately it still doesn't work.
Following is the error-
Time (on server): Wed Oct 18 2017 10:06:10 GMT-0700 (Pacific Daylight Time)
2017-10-18 10:06:10,286 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2017-10-18 10:06:10,302 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: DBCR-443, actionId: 1, file: <inline script>
groovy.lang.MissingPropertyException: No such property: event for class: Script210
 at Script210.run(Script210.groovy:17)
Hey Martin!!!!!!!!
Thanks soooooo much!!!!!!! Been struggling from past 2 days!
It worked!
if (issue.getIssueType().name == "RE Task")
One more help  - I want to add user as a watcher based on task type and specific components.
Could you help me with that please?
MoroSystems Support
October 19, 2017
Hello Pritesh,
sorry I couldn't answer you sooner but I see by your posted answer that you made it past your problem. Great to hear that!
