Problem Set up Jira/Confluence and ADFS with SAML Single Sign On Plugin
Portable Name
August 17, 2020
Colleagues, hello everyone. Need help as I ran into the problem of sso jira / confluence implementation via SAML Single Sign On Plugin on Windows Server 2016 st
I do everything according to the instructions as indicated there https://wiki.resolution.de/doc/saml-sso/3.6.x/confluence/setup-guides-for-saml-sso/microsoft-ad-fs/ad-fs-with -ldap-user-directory
I get to the point when I need to test (follow the link through another browser or incognito mode). I am thrown to the ADFS page, I enter my data and get an error:
Having understood a little, I realized that most likely I need to turn off the Automatically update relying party, since there is not a single SAML on the Endpoints tab, but the question immediately arose, what should I add there and did I understand correctly?
Rules are also added
Where am I going wrong?
Rudy Holtkamp
The quickest way to resolve this is to contact resolution right away: https://resolution.atlassian.net/servicedesk/customer/portal/1
They give phenomenal support and are the best people to help you.
Christian Reichert _resolution_
August 17, 2020
HI!
I work for resolution - and the best thing might be like @Rudy Holtkamp suggests to open a support case with us or to schedule a screen share: https://resolution.de/go/calendly
Unfortunately, your error screen is in a language I don't understand - but looking at the ADFS Setup - showing no endpoints is not correct. It looks like you have not importer our plugin's metadata on ADFS or something went wrong there.
Chris
Portable Name
August 17, 2020
Hi.
How can I manually import your plugin data into ADFS?
As I understand it, I take the link from the plugin and insert it into the endpoints?
If so, what does this link look like and where can I get it?
