Problem after Jira and Postgresql upgrade
Barry Kavanagh
We upgraded from Jira Server 8.2.2 to 8.19.0 and from Postgresql 9.6.11 to 12.8 on Windows Server 2012 R2. There seems to be a problem with JDBC. See log below.
2021-11-02 16:40:55,598+0000 localhost-startStop-1 INFO [c.a.jira.startup.JiraHomeStartupCheck] The jira.home directory 'D:\Program Files\Atlassian\Application Data\JIRA' is validated and locked for exclusive use by this instance.
2021-11-02 16:40:55,911+0000 localhost-startStop-1 WARN [o.a.catalina.util.SessionIdGeneratorBase] Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [301] milliseconds.
2021-11-02 16:40:56,105+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
Jira starting...
2021-11-02 16:40:56,305+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
___ Environment _____________________________
JIRA Build : 8.19.0#819000-sha1:47bbf34f7e2d88d8af7d579f0393cc03c448e7ba
Build Date : Thu Aug 26 00:00:00 BST 2021
JIRA Installation Type : Standalone
Application Server : Apache Tomcat/8.5.65 - Servlet API 3.1
Java Version : 11.0.8 - AdoptOpenJDK
Current Working Directory : C:\Program Files\Atlassian\JIRA\bin
Maximum Allowable Memory : 768MB
Total Memory : 384MB
Free Memory : 258MB
Used Memory : 126MB
Memory Pool: CodeHeap 'non-nmethods' : CodeHeap 'non-nmethods': init = 7602176(7424K) used = 2918400(2850K) committed = 7602176(7424K) max = 7602176(7424K)
Memory Pool: Metaspace : Metaspace: init = 0(0K) used = 28447824(27781K) committed = 29409280(28720K) max = -1(-1K)
Memory Pool: CodeHeap 'profiled nmethods' : CodeHeap 'profiled nmethods': init = 33554432(32768K) used = 11108992(10848K) committed = 33554432(32768K) max = 264634368(258432K)
Memory Pool: Compressed Class Space : Compressed Class Space: init = 0(0K) used = 3081216(3009K) committed = 3538944(3456K) max = 1073741824(1048576K)
Memory Pool: G1 Eden Space : G1 Eden Space: init = 27262976(26624K) used = 96468992(94208K) committed = 240123904(234496K) max = -1(-1K)
Memory Pool: G1 Old Gen : G1 Old Gen: init = 375390208(366592K) used = 22623392(22093K) committed = 148897792(145408K) max = 805306368(786432K)
Memory Pool: G1 Survivor Space : G1 Survivor Space: init = 0(0K) used = 13631488(13312K) committed = 13631488(13312K) max = -1(-1K)
Memory Pool: CodeHeap 'non-profiled nmethods' : CodeHeap 'non-profiled nmethods': init = 33554432(32768K) used = 3844480(3754K) committed = 33554432(32768K) max = 264634368(258432K)
JVM Input Arguments : --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED -Djava.util.logging.config.file=C:\Program Files\Atlassian\JIRA\conf\logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Xms384m -Xmx768m -XX:InitialCodeCacheSize=32m -XX:ReservedCodeCacheSize=512m -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory -XX:-OmitStackTraceInFastThrow -Djava.locale.providers=COMPAT -Datlassian.plugins.startup.options= -Djdk.tls.ephemeralDHKeySize=2048 -Djava.protocol.handler.pkgs=org.apache.catalina.webresources -Xlog:gc*:file="C:\PROGRA~1\ATLASS~1\JIRA\bin\..\logs\atlassian-jira-gc-%t.log":tags,time,uptime,level:filecount=5,filesize=20M -XX:+ExplicitGCInvokesConcurrent -Dignore.endorsed.dirs= -Dcatalina.base=C:\Program Files\Atlassian\JIRA -Dcatalina.home=C:\Program Files\Atlassian\JIRA -Djava.io.tmpdir=C:\Program Files\Atlassian\JIRA\temp
Java Compatibility Information : JIRA version = 8.19.0, Java Version = 11.0.8
___ Java System Properties ________________
atlassian.plugins.startup.options :
atlassian.standalone : JIRA
awt.toolkit : sun.awt.windows.WToolkit
catalina.base : C:\Program Files\Atlassian\JIRA
catalina.home : C:\Program Files\Atlassian\JIRA
catalina.useNaming : true
common.loader : "${catalina.base}/lib",
"${catalina.base}/lib/*.jar",
"${catalina.home}/lib",
"${catalina.home}/lib/*.jar"
file.encoding : Cp1252
ignore.endorsed.dirs :
java.awt.graphicsenv : sun.awt.Win32GraphicsEnvironment
java.awt.headless : true
java.awt.printerjob : sun.awt.windows.WPrinterJob
java.class.version : 55.0
java.home : C:\Program Files\Atlassian\Confluence\jre
java.io.tmpdir : C:\Program Files\Atlassian\JIRA\temp
java.locale.providers : COMPAT
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.protocol.handler.pkgs : org.apache.catalina.webresources
java.runtime.name : OpenJDK Runtime Environment
java.runtime.version : 11.0.8+10
java.specification.name : Java Platform API Specification
java.specification.vendor : Oracle Corporation
java.specification.version : 11
java.util.logging.config.file : C:\Program Files\Atlassian\JIRA\conf\logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : AdoptOpenJDK
java.vendor.url : https://adoptopenjdk.net/
java.vendor.url.bug : https://github.com/AdoptOpenJDK/openjdk-support/issues
java.vendor.version : AdoptOpenJDK
java.version : 11.0.8
java.version.date : 2020-07-14
java.vm.compressedOopsMode : 32-bit
java.vm.info : mixed mode
java.vm.name : OpenJDK 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Oracle Corporation
java.vm.specification.version : 11
java.vm.vendor : AdoptOpenJDK
java.vm.version : 11.0.8+10
jdk.debug : release
jdk.tls.ephemeralDHKeySize : 2048
mail.mime.decodeparameters : true
org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
org.dom4j.factory : com.atlassian.core.xml.InterningDocumentFactory
os.arch : amd64
os.name : Windows Server 2012 R2
os.version : 6.3
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.tomcat.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.naming.,
org.apache.tomcat.
server.loader :
shared.loader :
sun.arch.data.model : 64
sun.boot.library.path : C:\Program Files\Atlassian\Confluence\jre\bin
sun.cpu.endian : little
sun.cpu.isalist : amd64
sun.desktop : windows
sun.io.unicode.encoding : UnicodeLittle
sun.java.command : org.apache.catalina.startup.Bootstrap start
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : Cp1252
sun.management.compiler : HotSpot 64-Bit Tiered Compilers
sun.os.patch.level :
sun.stderr.encoding : cp850
sun.stdout.encoding : cp850
tomcat.util.buf.StringCache.byte.enabled : true
tomcat.util.scan.StandardJarScanFilter.jarsToScan : log4j-taglib*.jar,
log4j-web*.jar,
log4javascript*.jar,
slf4j-taglib*.jar
tomcat.util.scan.StandardJarScanFilter.jarsToSkip : annotations-api.jar,
ant-junit*.jar,
ant-launcher.jar,
ant.jar,
asm-*.jar,
aspectj*.jar,
bootstrap.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-jmx-remote.jar,
catalina-storeconfig.jar,
catalina-tribes.jar,
catalina-ws.jar,
catalina.jar,
cglib-*.jar,
cobertura-*.jar,
commons-beanutils*.jar,
commons-codec*.jar,
commons-collections*.jar,
commons-daemon.jar,
commons-dbcp*.jar,
commons-digester*.jar,
commons-fileupload*.jar,
commons-httpclient*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-logging*.jar,
commons-math*.jar,
commons-pool*.jar,
dom4j-*.jar,
easymock-*.jar,
ecj-*.jar,
el-api.jar,
geronimo-spec-jaxrpc*.jar,
h2*.jar,
hamcrest-*.jar,
hibernate*.jar,
httpclient*.jar,
icu4j-*.jar,
jasper-el.jar,
jasper.jar,
jaspic-api.jar,
jaxb-*.jar,
jaxen-*.jar,
jdom-*.jar,
jetty-*.jar,
jmx-tools.jar,
jmx.jar,
jsp-api.jar,
jstl.jar,
jta*.jar,
junit-*.jar,
junit.jar,
log4j*.jar,
mail*.jar,
objenesis-*.jar,
oraclepki.jar,
oro-*.jar,
servlet-api-*.jar,
servlet-api.jar,
slf4j*.jar,
taglibs-standard-spec-*.jar,
tagsoup-*.jar,
tomcat-api.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-i18n-*.jar,
tomcat-jdbc.jar,
tomcat-jni.jar,
tomcat-juli-adapters.jar,
tomcat-juli.jar,
tomcat-util-scan.jar,
tomcat-util.jar,
tomcat-websocket.jar,
tools.jar,
websocket-api.jar,
wsdl4j*.jar,
xercesImpl.jar,
xml-apis.jar,
xmlParserAPIs-*.jar,
xmlParserAPIs.jar,
xom-*.jar
user.country : GB
user.dir : C:\Program Files\Atlassian\JIRA\bin
user.home : C:\Users\ocenetadmin
user.language : en
user.name : ocenetadmin
user.script :
user.timezone : Europe/London
user.variant :
2021-11-02 16:40:57,113+0000 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from D:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
 Created function based indices for entity "ReindexComponent"
2021-11-02 16:41:03,719+0000 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Created function based indices for entity "ClusterNodeHeartbeat"
2021-11-02 16:41:03,719+0000 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Created function based indices for entity "ClusterNode"
2021-11-02 16:41:03,719+0000 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Created function based indices for entity "NotificationScheme"
2021-11-02 16:41:03,719+0000 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Created function based indices for entity "Group"
2021-11-02 16:41:03,719+0000 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Created function based indices for entity "IssueSecurityScheme"
2021-11-02 16:41:03,723+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is configured. Now running Database Checklist Launcher
2021-11-02 16:41:03,734+0000 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseChecklistLauncher] Jira database startup checks completed successfully.
2021-11-02 16:41:03,736+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is configured. Now running Post database-configuration launchers
2021-11-02 16:41:08,678+0000 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from D:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2021-11-02 16:41:08,684+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Trying to get encrypted password from xml and decrypt it
2021-11-02 16:41:08,685+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Database password decryption not performed.
2021-11-02 16:41:09,068+0000 JIRA-Bootstrap INFO [c.a.jira.propertyset.CachingOfBizPropertyEntryStore] DbBackedCachedPropertySetManager.jira.properties.cache stats disabled: NoOpPropertyEntryStoreStats
2021-11-02 16:41:10,328+0000 JIRA-Bootstrap INFO [c.a.jira.propertyset.CachingOfBizPropertyEntryStore] UserPropertyManager.ApplicationUser.cache stats disabled: NoOpPropertyEntryStoreStats
2021-11-02 16:41:10,333+0000 JIRA-Bootstrap INFO [c.a.jira.i18n.CachingI18nFactory] [i18n-caching-factory] Created
2021-11-02 16:41:11,432+0000 JIRA-Bootstrap INFO [c.a.j.c.embedded.ofbiz.OfBizUserDao] Using full user cache
2021-11-02 16:41:11,733+0000 JIRA-Bootstrap INFO [c.a.j.c.cache.pauser.NonClusteredReplicationPauserManager] Non-clustered mode: ReplicationPauserManager implemented by NonClusteredReplicationPauserManager
2021-11-02 16:41:11,885+0000 JIRA-Bootstrap INFO [c.a.c.e.c.a.j.p.util.CachingProjectKeyStore.cache] Cache com.atlassian.jira.project.util.CachingProjectKeyStore.cache was flushed
2021-11-02 16:41:11,887+0000 JIRA-Bootstrap INFO [c.a.jira.propertyset.CachingOfBizPropertyEntryStore] ProjectPropertiesManager.Project.cache stats disabled: NoOpPropertyEntryStoreStats
2021-11-02 16:41:12,374+0000 JIRA-Bootstrap INFO [c.a.jira.versioning.TransactionSupportHelper] [VERSIONING] creating pool of size: 50 for running required-new-transaction to be used by versioning.
2021-11-02 16:41:12,450+0000 JIRA-Bootstrap INFO [c.a.jira.propertyset.CachingOfBizPropertyEntryStore] com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.cache stats enabled: TotalAndSnapshotPropertyEntryStoreStats
2021-11-02 16:41:12,555+0000 JIRA-Bootstrap INFO [c.a.c.e.c.a.j.security.GlobalPermissionsCache.permissions] Cache com.atlassian.jira.security.GlobalPermissionsCache.permissions was flushed
2021-11-02 16:41:12,677+0000 JIRA-Bootstrap INFO [c.a.j.issue.index.DefaultIndexManager] Legacy mode for reIndex(issue): com.atlassian.jira.issue.reindex.legacy.mode=false
2021-11-02 16:41:12,678+0000 JIRA-Bootstrap INFO [c.a.j.issue.index.DefaultIndexManager] Legacy mode for reIndex(issue): com.atlassian.jira.issue.reindex.legacy.mode=false
2021-11-02 16:41:14,507+0000 http-nio-8080-exec-1 ERROR anonymous 1001x1x1 - 192.168.1.188 /secure/johnson/data [c.atlassian.instrumentation.Instrument] Unable to snapshot thread local operations (implementation of OpTimerFactory is not a ThreadLocalOpTimerFactory): null
2021-11-02 16:41:14,598+0000 http-nio-8080-exec-1 WARN anonymous 1001x1x1 - 192.168.1.188 /secure/johnson/data [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/johnson/data
2021-11-02 16:41:15,689+0000 JIRA-Bootstrap INFO [c.a.c.e.c.a.j.i.f.screen.CachingFieldScreenStore.allScreensCache] Cache com.atlassian.jira.issue.fields.screen.CachingFieldScreenStore.allScreensCache was flushed
2021-11-02 16:41:15,690+0000 JIRA-Bootstrap INFO [c.a.c.e.c.a.j.i.f.screen.CachingFieldScreenStore.fieldScreenCache] Cache com.atlassian.jira.issue.fields.screen.CachingFieldScreenStore.fieldScreenCache was flushed
2021-11-02 16:41:15,964+0000 JIRA-Bootstrap INFO [c.a.jira.upgrade.PluginUpgradeListener] [plugin-upgrade-listener] Created
2021-11-02 16:41:15,967+0000 JIRA-Bootstrap INFO [c.a.jira.plugin.JiraCacheResetter] [jira-cache-reseter] Created and registered for events
2021-11-02 16:41:15,972+0000 JIRA-Bootstrap INFO [c.a.jira.plugin.PluginTransactionListener] [plugin-transaction] Created, registered for events and scheduled stats job every: 5 min
2021-11-02 16:41:16,004+0000 JIRA-Bootstrap INFO [c.a.jira.i18n.CachingI18nFactory] [i18n-caching-factory] Registering for events
2021-11-02 16:41:16,029+0000 JIRA-Bootstrap INFO [c.a.jira.plugin.JiraCacheResetter] [jira-cache-reseter] Initialized.
2021-11-02 16:41:16,029+0000 JIRA-Bootstrap INFO [c.a.jira.plugin.PluginTransactionListener] [plugin-transaction] Initialized.
2021-11-02 16:41:16,215+0000 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseLauncher] Database transactions enabled: true
2021-11-02 16:41:16,216+0000 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseLauncher] Using JIRA's default for database transaction isolation level: 2
2021-11-02 16:41:16,227+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
Database configuration OK
___ Database Configuration ________________
Loading entityengine.xml from : file:/C:/Program%20Files/Atlassian/JIRA/atlassian-jira/WEB-INF/classes/entityengine.xml
Entity model field type name : postgres72
Entity model schema name : public
Database Version : PostgreSQL - 12.8
Database Driver : PostgreSQL JDBC Driver - 42.2.23
Database URL : jdbc:postgresql://localhost:5433/jiradb
Database JDBC config : postgres72 jdbc:postgresql://localhost:5433/jiradb
2021-11-02 16:41:16,369+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
___ Starting the JIRA Plugin System _________________
2021-11-02 16:41:16,375+0000 JIRA-Bootstrap INFO [c.a.plugin.manager.DefaultPluginManager] Plugin system earlyStartup begun
2021-11-02 16:41:16,733+0000 JIRA-Bootstrap INFO [c.a.c.e.c.a.j.i.c.manager.CachedOptionsManager.optionsCache] Cache com.atlassian.jira.issue.customfields.manager.CachedOptionsManager.optionsCache was flushed
2021-11-02 16:41:16,733+0000 JIRA-Bootstrap INFO [c.a.c.e.c.a.j.i.c.manager.CachedOptionsManager.optionCache] Cache com.atlassian.jira.issue.customfields.manager.CachedOptionsManager.optionCache was flushed
2021-11-02 16:41:16,733+0000 JIRA-Bootstrap INFO [c.a.c.e.c.a.j.i.c.manager.CachedOptionsManager.parentCache] Cache com.atlassian.jira.issue.customfields.manager.CachedOptionsManager.parentCache was flushed
2021-11-02 16:41:16,733+0000 JIRA-Bootstrap INFO [c.a.c.e.c.a.j.i.c.manager.CachedOptionsManager.valueCache] Cache com.atlassian.jira.issue.customfields.manager.CachedOptionsManager.valueCache was flushed
2021-11-02 16:41:16,734+0000 JIRA-Bootstrap INFO [c.a.c.e.c.a.j.i.c.manager.CachedOptionsManager.allCache] Cache com.atlassian.jira.issue.customfields.manager.CachedOptionsManager.allCache was flushed
2021-11-02 16:41:16,825+0000 JIRA-Bootstrap INFO [c.a.jira.template.DefaultTemplateValidationConfigProvider] Started parsing of email-templates-to-validate.xml
2021-11-02 16:41:16,893+0000 JIRA-Bootstrap INFO [c.a.jira.template.DefaultTemplateValidationConfigProvider] Parsed 32 template configs
2021-11-02 16:41:16,930+0000 JIRA-Bootstrap INFO [c.a.jira.cluster.ClusterSettings] [CLUSTER-STATE] Value for system property key jira.cluster.retention.period.in.days was set to PT48H
2021-11-02 16:41:25,425+0000 FelixStartLevel WARN [o.e.g.b.e.internal.support.ExtenderConfiguration] Gemini Blueprint extensions bundle not present, annotation processing disabled.
2021-11-02 16:41:29,674+0000 http-nio-8080-exec-3 WARN anonymous 1001x3x1 - 192.168.1.188 /secure/johnson/data [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/johnson/data
2021-11-02 16:41:31,213+0000 JIRA-Bootstrap ERROR [c.a.p.osgi.util.OsgiHeaderUtil] Cannot get manifest resource from plugin artifact 'jdbc4jql-9.11.1_1631120743575.jar': Cannot open JAR file: D:\Program Files\Atlassian\Application Data\JIRA\plugins\.osgi-plugins\transformed-plugins\jdbc4jql-9.11.1_1631120743575.jar
2021-11-02 16:41:31,220+0000 JIRA-Bootstrap ERROR [c.a.plugin.loaders.ScanningPluginLoader] Unable to deploy plugin 'com.kintosot.jira.jdbc4jql' from 'Unit: D:\Program Files\Atlassian\Application Data\JIRA\plugins\installed-plugins\jdbc4jql-9.11.1.jar (1631120743575)'.
2021-11-02 16:41:31,221+0000 JIRA-Bootstrap ERROR [c.a.plugin.loaders.ScanningPluginLoader] Because of the following exception:
java.lang.IllegalArgumentException: File must be a jar: D:\Program Files\Atlassian\Application Data\JIRA\plugins\.osgi-plugins\transformed-plugins\jdbc4jql-9.11.1_1631120743575.jar
at com.atlassian.plugin.osgi.factory.transform.JarUtils.withJar(JarUtils.java:77)2021-11-02 16:40:55,598+0000 localhost-startStop-1 INFO [c.a.jira.startup.JiraHomeStartupCheck] The jira.home directory 'D:\Program Files\Atlassian\Application Data\JIRA' is validated and locked for exclusive use by this instance.
Jira starting...
Free Memory : 258MB
Used Memory : 126MB
jdk.debug : release
os.arch : amd64
os.version : 6.3
org.apache.coyote.,
org.apache.jasper.,
org.apache.tomcat.
java.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.naming.,
org.apache.tomcat.
server.loader :
shared.loader :
log4j-web*.jar,
slf4j-taglib*.jar
ant-junit*.jar,
ant-launcher.jar,
ant.jar,
asm-*.jar,
aspectj*.jar,
bootstrap.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-ws.jar,
catalina.jar,
cglib-*.jar,
cobertura-*.jar,
commons-codec*.jar,
commons-daemon.jar,
commons-dbcp*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-math*.jar,
commons-pool*.jar,
dom4j-*.jar,
easymock-*.jar,
ecj-*.jar,
el-api.jar,
h2*.jar,
hamcrest-*.jar,
hibernate*.jar,
httpclient*.jar,
icu4j-*.jar,
jasper-el.jar,
jasper.jar,
jaspic-api.jar,
jaxb-*.jar,
jaxen-*.jar,
jdom-*.jar,
jetty-*.jar,
jmx-tools.jar,
jmx.jar,
jsp-api.jar,
jstl.jar,
jta*.jar,
junit-*.jar,
junit.jar,
log4j*.jar,
mail*.jar,
objenesis-*.jar,
oraclepki.jar,
oro-*.jar,
servlet-api-*.jar,
servlet-api.jar,
slf4j*.jar,
tagsoup-*.jar,
tomcat-api.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-i18n-*.jar,
tomcat-jdbc.jar,
tomcat-jni.jar,
tomcat-juli.jar,
tomcat-util.jar,
tools.jar,
websocket-api.jar,
wsdl4j*.jar,
xercesImpl.jar,
xml-apis.jar,
xmlParserAPIs.jar,
xom-*.jar
user.country : GB
user.language : en
user.script :
user.variant :
2021-11-02 16:40:57,207+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Trying to get encrypted password from xml and decrypt it
.....INFO MKESSAGES REMOVED...
at com.atlassian.plugin.osgi.factory.transform.JarUtils.withJar(JarUtils.java:77)asasa
SERVER
