Hello everyone I'm struggle just since a few days with developing a Refapp i get an error when i would like to start the aplication in confluence and i cant solved it.
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.atlassian.plugins.tutorial.refapp</groupId>
<artifactId>adminUI</artifactId>
<version>1.0.0-SNAPSHOT</version>
<organization>
<name>Wi</name>
<url>http://www.wi.com/</url>
</organization>
<name>adminUI</name>
<description>This is the com.atlassian.plugins.tutorial.refapp:adminUI plugin for Atlassian Refapp.</description>
<packaging>atlassian-plugin</packaging>
<dependencies>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.servlet</groupId>
<artifactId>javax.servlet-api</artifactId>
<scope>provided</scope>
</dependency>
<dependency>
<groupId>com.atlassian.templaterenderer</groupId>
<artifactId>atlassian-template-renderer-api</artifactId>
<version>1.3.1</version>
</dependency>
<dependency>
<groupId>com.atlassian.sal</groupId>
<artifactId>sal-api</artifactId>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<scope>runtime</scope>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-simple</artifactId>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<dependency>
<artifactId>slf4j-api</artifactId>
<version>1.6.6</version>
</dependency>
<dependency>
<groupId>org.mockito</groupId>
<artifactId>mockito-all</artifactId>
<version>1.8.5</version>
<scope>test</scope>
</dependency>
</dependencies>
<dependencyManagement>
<dependencies>
<dependency>
<groupId>com.atlassian.platform</groupId>
<artifactId>platform</artifactId>
<version>${platform.version}</version>
<type>pom</type>
<scope>import</scope>
</dependency>
<dependency>
<artifactId>third-party</artifactId>
<type>pom</type>
</dependency>
</dependencies>
</dependencyManagement>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>refapp-maven-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${refapp.version}</productVersion>
<confluence.version>RELEASE</confluence.version>
<enableQuickReload>true</enableQuickReload>
<enableFastdev>false</enableFastdev>
<!-- See here for an explanation of default instructions: -->
<!-- https://developer.atlassian.com/docs/advanced-topics/configuration-of-instructions-in-atlassian-plugins -->
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<!-- Add package to export here -->
<Export-Package>
com.atlassian.plugins.tutorial.refapp.api,
</Export-Package>
<!-- Add package import here -->
<Import-Package>
*;version="0";resolution:=optional
</Import-Package>
<!-- Ensure plugin is spring powered -->
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
<goal>install</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
<includeExclude>-com.atlassian.plugin.spring.scanner.annotation.*</includeExclude>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<platform.version>5.0.0</platform.version>
<refapp.version>5.0.0</refapp.version>
<amps.version>8.0.2</amps.version>
<plugin.testrunner.version>2.0.1</plugin.testrunner.version>
<atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
<!-- This property ensures consistency between the key in atlassian-plugin.xml
and the OSGi bundle's key. -->
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
</properties>
</project>
[INFO] ------------------------------------------------------------------------
[ERROR] Unknown lifecycle phase "confluence". You must specify a valid lifecycle phase or a goal in the format <plugin-prefix>:<goal> or <pl
ugin-group-id>:<plugin-artifact-id>[:<plugin-version>]:<goal>. Available lifecycle phases are: validate, initialize, generate-sources, proce
ss-sources, generate-resources, process-resources, compile, process-classes, generate-test-sources, process-test-sources, generate-test-reso
urces, process-test-resources, test-compile, process-test-classes, test, prepare-package, package, pre-integration-test, integration-test, p
ost-integration-test, verify, install, deploy, pre-clean, clean, post-clean, pre-site, site, post-site, site-deploy. -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/LifecyclePhaseNotFoundException
Der Befehl "cmd" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
Why you have install goal in your pom
<executions>
<execution>
<goals>
</goals>
i think this is the problem in your pom
