I use JIRA Diagramming by Creatively to create diagram into issue description.
When I try to export the issue descrition field using XPorter, the diagram is not render correctly.
I can see in the document exported only a "X" sign.
There is a method to export descrition with an images?
Hi @Samuele Pretini,
Xporter allow you to do that.
You just need to put this in your template:
${wiki:Description}Try it.
Rui Rodrigues.
