Problem in create link between jira and confluence
Kaveh M Mehr August 14, 2019
Hi all
Is there any expert ?
I have a question about linking jira and confluence.
When  i try to create applink from confluence to jira i get this error.
"Unable to auto-configure a Consumer as the remote Consumer-Info could not be found."
It seems that jira is not reachable from confluence.
I examine the network connection by telnet and curl every thing is OK.
There is not any SSL  on my tomcat.
Because our Jira Server is in behind a WAF with SSL,  I add a new connector in Server.XML and change BaseURL to new connector temporarily,  but no thing changes.
Then i try to check manifest ,so i run the following command ,it returns normal manifest but at the last line there is a strange phrase  "Connection #0 to host xxx.xx.x.xxx left intact"
curl -H "Accept: application/json" http://HOST/ContextPath/rest/applinks/1.0/manifest -v
What is the problem? How i should find a clue?
