Hello all,
I am using the 'Fast-track transition an issue ' post function two times in my workflow.
Sometimes, there is a problem : some buttons continue to appear whereas they should not appear... because of the use of post function. When I refresh my internet page using F5 key, they automatically disapear...
Did you meet the same problem with this post function ? do you have any solutions ?
Thanks a lot,
Christophe
Hi Chris,
That seems odd. I'm not sure what might cause this problem, however my current suspicion that the problem might be related to indexing problem. Can you try to perform the following steps and check whether the problem still appears:
Hope that was helpful.
Cheers.
