i have a problem with added a Worklog to my report in EasyBI.
In this moment I have only spent hours in issue and i must pass to Drill Trough Worklogs.
Finally I would like to have a view containing Worklog(comment).
Hi @Łukasz Gut ,
You can use eazyBI advanced settings to import worklog comments as a separate dimension; see documentation here: https://docs.eazybi.com/eazybi/data-import/data-from-jira/jira-custom-fields/javascript-calculated-custom-fields#JavaScriptcalculatedcustomfields-Calculatedworklogcustomfield
Best,
Gerda // support@eazybi.com
@Łukasz Gut
If you use "Hours spent" with dimensions "Logged by" and "Time" then it will group information about the logged hours per user per time (Hours spent is linked to "Time" dimension by worklog start date).
Also, you can use an option drill through worklogs for measure "Hours spent" to see details, including comments or use the above solution to import it as dimension.
What information is still missing from the "Worklog" tab?
best,
Gerda
Yesy yes Gerda,
but when i try to use the above solution do import it as dimension a don't see this information im my raport.
Please help me:-(
